[GRASS-user] v.out.ogr
Hi grass users,
i'm trying to export a grass vector and generate a shapefile using v.out.ogr. the vector contains 4 points and 6 boundaries each has its own centroids.
the output shapefile contains 4 objects out of 10. WHY? How can I get all the objects?
(i created the vector using v.patch from 2 separate vectors, one containg 4 points and the other containing 6 boundaries + centroids).
thanks
silvia
Silvia Simoni PhD
DICA - Department of Civil and Environmental Engineering
Universita' di Trento
via Mesiano 77, 38100 Trento, ITALY
tel. +39 0461 882610
fax. +39 0461 882672
e-mail: silvia.simoni@ing.unitn.it
Silvia Simoni wrote:
Hi grass users,
own centroids.
all the objects?
thanks
silvia
I don't believe that shapefiles can hold multiple vector types. It
sounds like you have both points and polygons. You can get the 4 pts
plus 6 centroids in one and the 6 boundaries in another if you like.
Alex
On Wed, Sep 10, 2008 at 10:42:12PM +0200, we recorded a bogon-computron collision of the <silvia.simoni@ing.unitn.it> flavor, containing:
Hi grass users,
own centroids.
all the objects?
Shapefiles can only hold one type of data (point, line, polygon) per shapefile.
You can't export a grass vector with both points and areas to a single
shapefile. You'll have to do it in two passes to two different files with
v.out.ogr and different "type=" parameters.
That is, it'll be as if you exported the data before having done the v.patch.
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"Argue for your limitations and sure enough, they're yours." -- R. Bach
Thanks Tom and Alex!
it works mow!
silvia
Hi grass users,
own centroids.
all the objects?
Silvia Simoni PhD
