… upon quick inspection:
the where 1 = 0 above looks strange to me.
But I don’t know what it could originate from.
ERROR: relation “grass_gis.apgb_aerial_2_i_segment_drained_
peat_with_exposed_haggs_vct” does not exist
LINE 1: select * from
grass_gis.APGB_aerial_2_i_segment_drained_peat…
DBMI-PostgreSQL driver error:
select * from grass_gis.APGB_aerial_2_i_segment_drained_peat with_exposed_haggs_vct where 1 = 0
ERROR: relation "grass_gis.apgb_aerial_2_i_segment_drained
peat_with_exposed_haggs_vct" does not exist
^ ERROR: Unable to describe table <grass_gis.APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vct>
I am trying to export a vector map to PostGIS. Has anyone come across the 'Unable to describe table' error? I suspect my config could be wrong.
v.out.postgis --overwrite input=APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vct@PERMANENT output=PG:dbname=webgis output_layer=APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vct options=FID=cat, GEOMETRY_NAME=wkb_geometry, SPATIAL_INDEX=YES, PRIMARY_KEY=YES
_with_exposed_haggs_vct where 1 = 0
ERROR: relation "grass_gis.apgb_aerial_2_i_segment_drained_
grass_gis.APGB_aerial_2_i_segment_drained_peat...
*ERROR: Unable to describe table* <grass_gis.APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vct>
It looks like it is trying to read the input attrubute table from postgresql (schema grass_gis). Do you use PostgreSQL as attribute table backend ? Could you provide the output of db.connect -p in that mapset ?
I am trying to export a vector map to PostGIS. Has anyone come across the ‘Unable to describe table’ error? I suspect my config could be wrong.
ore precise would be
v.db.connect -p APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vct@PERMANENT
because there may be a bug in v.out.postgis, not properly reading the database connection of the input vector.
v.db.connect -p APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vector
Vector map <APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vector> is connected by:
layer <1/grass_gis.APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vector> table <grass_gis.APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vector> in database through driver with key
I recall some years ago you had to delete the ‘db.login’ file and recreate it but this would lose the connection to the vector layer attribute table (sqlite.db).
I recall some years ago you had to delete the 'db.login' file and recreate it but this would lose the connection to the vector layer attribute table (sqlite.db).
Paul Shapley
On 28 June 2018 at 13:22, Markus Metz <markus.metz.giswork@gmail.com <mailto:markus.metz.giswork@gmail.com>> wrote:
On Thu, Jun 28, 2018 at 1:40 PM, Moritz Lennert
<mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>>
wrote:
> On 28/06/18 09:59, Paul Shapley wrote:
>> Hi,
could be wrong.
PRIMARY_KEY=YES
that mapset ?
v.db.connect -p
v.db.select APGB_aerial_2_i_segment_drained_peat_with_exposed_haggs_vector
Unable to select:
SELECT * FROM grass_gis.APGB_aerial_2_i_segment_drained_peat with_exposed_haggs_vector
peat_with_exposed_haggs_vector" does not exist
LINE 1: SELECT * FROM
Unable to select:
ERROR: Unable to open select cursor
(Fri Jun 29 11:24:18 2018) Command finished (0 sec)
could be wrong.
PRIMARY_KEY=YES
that mapset ?
v.db.connect -p
Unable to select:
Unable to select:
So, apparently your vector map is linked to a table that does not exist. Or it exists but not in the schema grass_gis. You will have to correct the link between the map and its attribute table before you can export it.
My apologies… it appears that the result of 'r.to.vect was indeed sending the attributes to postgres but i was expecting them to appear in sqlite had i ‘refreshed’ the posgres schema i would have seen them.
Unable to select:
Unable to select:
