[GRASS-user] v.overlay attribute table problem
I'm using v.overlay to intersect two layers : mpnetwork and
management_polygones.
The output layer is base_cells.
I'm wondering why some of the initial attribute values aren't kept in
the outputted merged table :
Vector 14 of management_polygons has a value for area_tot attribute :
GRASS 6.2.0 (ALMERIA):~/Documents/ucl/alert/grass > v.db.select
map=management_polygones column=cat,area_tot where="cat=14"
cat|area_tot
14|1195927.2564
In the merged attribute table, it seems that b_area_tot for b_cat 14 is
null ... :
map=base_cells column=cat,a_cat,b_cat,b_area_tot where="b_cat=14"
cat|a_cat|b_cat|b_area_tot
62|18|14|0
63|2|14|0
65|2|14|0
67|41|14|0
70|35|14|0
73|1|14|0
86|13|14|0
87|8|14|0
105|31|14|0
113|32|14|0
118|39|14|0
119|37|14|0
121|40|14|0
131|3|14|0
132|6|14|0
133|28|14|0
How is this possible ? The merged attribute table should keep all the
input values according to the documentation. Am I wrong ?
Didrik
PS : running Grass 6.2.0 on a Debian system
Stranger,
I've tested the following : create the intersection from layer B to
layer A compared with intersection from layer A to layer B :
CASE 1 :
v.overlay ainput=mpnetwork atype=area binput=management_polygones
atype=area output=base_cells operator=and
CASE 2 :
v.overlay ainput=management_polygones atype=area binput=mpnetwork
The resulting intersection are different and seems to be uncorrect :
CASE 1 :
map=base_cells column=a_cat,b_cat,a_area_tot,b_area_tot where="a_cat=37"
a_cat|b_cat|a_area_tot|b_area_tot
37|10|1000000|15000
37|13|1000000|0
37|1|1000000|0
37|8|1000000|0
37|14|1000000|0
37|11|1000000|1527000
CASE 2 :
map=base_cells column=a_cat,b_cat,a_area_tot,b_area_tot where="b_cat=37"
... this is a very strange behaviour ... the CASE 1 gives the correct
intersection and not the CASE2 ...
Didrik
I've made some progress :
Using two grid generated to test the intersection problem, I get correct
intersection and correct attribute table.
So the problem is related to the input file I'm using...
Here is a screenshot of the two layers :
http://downloads.itae.be/grass_overlay.jpg
Is there any reason why the overlay operation seems to be correctly done
but the attribute table is not correctly created ?
Didrik
Didrik
After lots of investigation, it seems all of this was related to the use
of the DBF backend.
I've switched to postgres and everything works fine now.
I've reported a bug on the grass bugtracker but I cannot add comments to
it. Does anybody knows how to get a login on Intevation RT ?
Didrik
