[GRASS-user] v.overlay Limited In wxPython GUI
On Feb 23, 2010, at 12:37 PM, grass-user-request@lists.osgeo.org wrote:
Date: Tue, 23 Feb 2010 09:46:13 -0800 (PST)
Subject: [GRASS-user] v.overlay Limited In wxPython GUI
To: grass-users@lists.osgeo.org
Message-ID: <alpine.LNX.2.00.1002230942540.6523@salmo.appl-ecosys.com>
Content-Type: TEXT/PLAIN; format=flowed; charset=US-ASCII
  I tried to extract the streams within a specific drainage basin using the
wxPython GUI and the v.overlay function. It fails because it assumes the
operation is 'or' (set UNION) and does not permit the user to select a
different operator.
  To write only those streams within the named basin to an output file
requires the set operator INTERSECT, or 'and.' I did not see anywhere on the
GUI window tabs where the operator could be selected. If I missed it, please
point that out to me. Else, consider adding a widget to select the operator.
Rich
I just looked at this in GRASS 7 and there is a pull down choice control for "operator defines features written to output vector map:" The pull-down lists and, or, not, and xor. Is this missing on GRASS 6.4?
Michael
2010/2/23 Michael Barton <michael.barton@asu.edu>:
it's not missing in G6.4.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Michael,
   Yup.
Rich
Martin,
   Aha! I did not see the vertical scroll bar on the Optional tab. It is
there near the bottom. My error.
Rich
   Turns out there's a vertical scroll bar on the Optional tab, and below
what's visible at the top of the tab is that option.
Rich
that requires GRASS to be built with GEOS support, which AFAIK
was added after the major feature freeze for 6.4.
Hamish
2010/2/23 Hamish <hamish_b@yahoo.com>:
GEOS support is related to v.select not v.overlay.
Martin
