[GRASS-user] v.overlay
Dear list,
I try to intersect a polygon theme with a mesh of lines using the v.overlay command. Executing this command results in the following message:
Copying binput lines ...
could not open the existing vector file 'Mesh16m on level 2
What does level 2 mean? And is there another option to intersect both themes holding the attributes of my polygon theme as well as areas?
Regards
Chris
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
2008/3/13, christian Brandt <chrisbrandt74@hotmail.com>:
'Level 2' means vector topology level. Try to rebuild topology of
Mesh16m using v.build.
Sorry, I do not fully understand this. Can you explain?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
