[GRASS-user] v.patch ERROR: Column names differ
Hi
I tried the following:
v.patch -a -e in=sewer_digit@sewer out=sewer_MN --overwrite
and received:
The columns names don't differ, only the order differs:
v.db.connect -c sewer_MN
TEXT|comment
INTEGER|cat
TEXT|pipe_id
DOUBLE PRECISION|pipe_length_m
DOUBLE PRECISION|pipe_size_mm
and:
v.db.connect -c sewer_digit@sewer
INTEGER|cat
TEXT|comment
TEXT|pipe_id
I'm using 6.3.0RC3, sqlite and sewer_digit is in a different mapset. If I
have to re-order the columns do you have any tips on how to do this?
Regards
Craig
View this message in context: http://www.nabble.com/v.patch-ERROR%3A--Column-names-differ-tp15481183p15481183.html
Craig,
On Thu, Feb 14, 2008 at 4:04 PM, Craig Leat <Craig@pid.co.za> wrote:
Hi
and received:
TEXT|comment
INTEGER|cat
TEXT|pipe_id
and:
INTEGER|cat
TEXT|comment
TEXT|pipe_id
Mhh, the column oder will be indeed the problem.
New columns are added to the right, but that's obviously annoying to
do manually.
It should be a general SQL join problem - any experts here?
Markus Neteler schrieb:
Craig,
Hi
and received:
TEXT|comment
INTEGER|cat
TEXT|pipe_id
and:
INTEGER|cat
TEXT|comment
TEXT|pipe_id
do manually.
grass-user mailing list
grass-user@lists.osgeo.org
I had a similar problem the other day while renaming columns. As Markus said its a problem that new columns are added to the right.So its a little tricky to get the correct order.
To see the current order use
db.select sewer_MN | line
this prints the first line of the table:
comment|cat|pipe_id|pipe_length_m|pipe_size_mm
Now use
v.db.renamecol sewer_MN col=pipe_length_m,pipe_length_m_tmp
and you get
comment|cat|pipe_id|pipe_size_mm|pipe_length_m_tmp
then use
v.db.renamecol sewer_MN col=pipe_length_m_tmp,pipe_length_m
and you get
I also tried to export the file as a .csv with db.out.ogr, to sort it with awk and to import it again with db.in.ogr -
could be the fastest way, but I couldn't import it again *grmpf* :o/
Got some error-messages like
ERROR: Input DSN <file> not found or not readable
So the rename-thing may be intricately but it works.
cheers
om shantih
Philipp
Now use
and you get
Hi Philipp
Thanks very much for the pointer, the v.db.renamecol trick to re-order the columns worked for me.
Best regards
Craig.
