On Thu, Sep 15, 2016 at 1:02 AM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
The target location has these PROJ_INFO parameters defined in a Shapefile
*.prj:
datum: nad83harn
ellps: grs80
proj: lcc
lat_1: 44.33333333333334
lat_2: 46
lat_0: 43.66666666666666
lon_0: -120.5
x_0: 2500000
y_0: 0
no_defs: defined
The source location has these PROJ_INFO parameters defined in the
metadata.xml with EPSG 2992:
name: NAD83 / Oregon Lambert (ft)
datum: nad83
ellps: grs80
proj: lcc
lat_1: 43
lat_2: 45.5
lat_0: 41.75
lon_0: -120.5
x_0: 399999.9999984
y_0: 0
no_defs: defined
nadgrids: WO
When I imported this OFGDB source and selected epsg 2992 a window with 6
flavors appeared. I selected #6: Washington/Oregon HARM adjustment.
yes, it would apply
nadgrids=WO
according to the list in the location manager selection window (I just tried here with EPSG 2992).
Apparently this was not used.
I checked:
- in GRASS GIS 7.2 is is used, should be ok:
g.proj -p
-PROJ_INFO-------------------------------------------------
name : NAD83 / Oregon Lambert (ft)
datum : nad83
ellps : grs80
proj : lcc
lat_1 : 43
lat_2 : 45.5
lat_0 : 41.75
lon_0 : -120.5
x_0 : 399999.9999984
y_0 : 0
no_defs : defined
nadgrids : WO
-PROJ_EPSG-------------------------------------------------
epsg : 2992
-PROJ_UNITS------------------------------------------------
unit : foot
units : feet
meters : 0.3048
Question: do you use 7.2.svn?
- in trunk (“7.3”) it is not used due to NAD file removal during the recent code sprint upon long discussions with the GDAL maintainer Even Rouault (https://trac.osgeo.org/grass/changeset/69211). Here it should use the respective file through GDAL/PROJ4 since we don’t want to keep our private copies any longer.
From the target location/mapset I tried v.proj
location=ODOT2014mapset=data_source.gdb input=state_roads_2014 (I renamed
the long original name to this with g.rename.) and was told there
was no projection conversion table available.
Sounds to me that you are using the trunk version of GRASS GIS?
Should I re-import the data and try to ensure that the HARM adjustment is
accepted, or is there a way of reprojecting the source to match the target?
In the first place I would use GRASS GIS 7.2.svn since the NAD management stuff in trunk is currently experimental.
It is a fairly complex beast. The idea is that GRASS no longer bothers about NAD and just receives related info from GDAL/PROJ4. Seems not to be complete yet (I’ll update https://trac.osgeo.org/grass/ticket/2456 accordingly).
For now, here a cmd line way for GRASS GIS 7.2:
create dummy location just in order to fetch the list
of available datums for given EPSG code:
grass72 -c epsg:2992 ~/grassdata/dummy --exec g.proj -t epsg=2992 datumtrans=-1
Cleaning up temporary files…
Creating new GRASS GIS location/mapset…
Executing <g.proj -t datumtrans=-1 epsg=2992> …
1
Used in whole nad83 region
towgs84=0.000,0.000,0.000
Default 3-Parameter Transformation (May not be optimum for older datums; use this only if no more appropriate options are available.)
2
Used in Florida
nadgrids=FL
Transforms ‘Old NAD83’ to ‘HPGN NAD83’
3
Used in Maryland
nadgrids=MD
4
Used in Tennessee
nadgrids=TN
5
Used in Wisconsin
nadgrids=WI
6
Used in Washington - Oregon
nadgrids=WO
Execution of <g.proj -t datumtrans=-1 epsg=2992> finished.
now generate location using EPSG code and related datumtransform #6:
grass72 -c epsg:2992 ~/grassdata/oregon2992_nad83_WO --exec g.proj -t epsg=2992 datumtrans=6 -p
Executing <g.proj -t epsg=2992 datumtrans=6 -p> …
datum : nad83
ellps : grs80
proj : lcc
lat_1 : 43
lat_2 : 45.5
lat_0 : 41.75
lon_0 : -120.5
y_0 : 0
no_defs : defined
nadgrids : WO
epsg : 2992
unit : foot
units : feet
meters : 0.3048
Execution of <g.proj -t epsg=2992 datumtrans=6 -p> finished.
eventually start using the new location
grass72 ~/grassdata/oregon2992_nad83_WO/PERMANENT/
But! When entering this location and running
g.proj -p
still nadgrids is not listed any more… confusing.
Anyone with more insights here?
