[GRASS-user] v.proj: lat or lon limits exceeded
Trying to re-project a vector file from location lon_lat to the project's
location fails:
Reprojecting primitives ...
WARNING: proj_trans() failed: latitude or longitude exceeded limits
ERROR: Unable to re-project vector map <anal_area@PERMANENT> from <lon_lat>
lon_lat/PERMANENT/PROJ_INFO has no geographic coordinates. The vector file
has these corners:
45.150100, -123.940000
45.145400, -123.940000
45.145400, -123.960000
45.150100, -123.960000
The project location's PROJ_INFO is:
datum: nad83harn
ellps: grs80
proj: lcc
lat_1: 43
lat_2: 45.5
lat_0: 41.75
lon_0: -120.5
x_0: 399999.9999999999
y_0: 0
no_defs: defined
The warning does not inform which location's limits are exceeded, and I need
to learn how to resolve this situation (and avoid future ones.)
Rich
On Fri, Jul 19, 2019 at 11:44 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
Trying to re-project a vector file from location lon_lat to the project’s
location fails:
Reprojecting primitives …
Which version of proj are you using? Note that proj 6 is not yet supported, neither by gdal 2.x nor by grass 7.x.
Markus M
ERROR: Unable to re-project vector map anal_area@PERMANENT from <lon_lat>
has these corners:
The project location’s PROJ_INFO is:
datum: nad83harn
ellps: grs80
proj: lcc
lat_1: 43
lat_2: 45.5
lat_0: 41.75
lon_0: -120.5
y_0: 0
no_defs: defined
The warning does not inform which location’s limits are exceeded, and I need
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Markus M,
proj-5.2.0
geos-3.7.2
gdal-2.2.4
And Slackware tends to stay back from the bleeding edges.
Rich
location fails:
has these corners:
the latitudes of -123.9x are smaller than -90, exceeding limits. Did you swap easting and northing?
Markus M
datum: nad83harn
ellps: grs80
proj: lcc
lat_1: 43
lat_2: 45.5
lat_0: 41.75
lon_0: -120.5
y_0: 0
no_defs: defined
Rich
Markus M,
Sigh. Obviously, yes. And I completely missed seeing this. I knew it was
something simple that I overlooked.
Thank you very much,
Rich
