Trying to copy separate location/data into a common location (named
'Oregon') with grass-6.4svn. I set /usr4/grassbase/Oregon as pwd and start
grass64. At the command line I enter:
GRASS 6.4.0svn (Oregon):/usr4/grassbase/Oregon > v.proj in=highways
location=/usr4/grassbase/highways/ mapset=rbs
and immediately get this fatal error:
ERROR: Mapset <rbs> in input location </usr4/grassbase/highways/> not found
yet it is there. Same error if I specify mapset=PERMANENT.
What have I done incorrectly?
Rich
martinl
November 18, 2009, 8:44pm
2
HI,
2009/11/18 Rich Shepard <rshepard@appl-ecosys.com>:
there should name of the location in given gisdbase, i.e. `location=highways`
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Martin,
Thank you. The command v.proj in=highways location=highways mapset=rbs
worked just fine.
Rich
