I want to use v.proj to reproject vector files from another location.
However when I open the location (B) where my reprojected vector file must
be safed, I can't choose my input vector file because it is in location (A).
Also when I open the (unprojected) vector file in location B, I can't select
the file. Or when I open location A, I can choose the input vector file, but
there is an error that I can't use 2 equal locations.
How does this work? I have tried several options, but they don't want to
work.
Hi everyone,
I'm using QGIS 1.7.0 and GRASS as a plug-in.
work.
Yes, the interface for the v.proj module doesn’t work. Can I suggest you try the v.proj command from the GRASS shell? (at the top of the Modules Tree). You should be in the target location. Start the gRASS shell, and type in:
v.proj input= map- location= output=
Thank you.
Kind regards,
Annelies
View this message in context: [http://osgeo-org.1803224.n2.nabble.com/v-proj-tp6775859p6775859.html](http://osgeo-org.1803224.n2.nabble.com/v-proj-tp6775859p6775859.html)
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
This mail was received via Mail-SeCure System.
