I have encountered an error using v.random. It segfaults whenever I try to
create some random points.
gdb v.random
(gdb) run output=test_points npoints=6 restrict=test column=Depth --v --o
Starting program: /usr/local/grass78/bin/v.random output=test_points npoints=6 restrict=test column=Depth --v --o
warning: the debug information found in "/lib64/ld-2.27.so" does not match "/lib64/ld-linux-x86-64.so.2" (CRC mismatch).
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
WARNING: Vector map <test_points> already exists and will be overwritten
WARNING: Table <test_points> linked to vector map <test_points> does not
exist
Using native format
Generating points...
0%
Program received signal SIGSEGV, Segmentation fault.
0x0000555555558c21 in main ()
(gdb) bt #0 0x0000555555558c21 in main ()
Is there anything else I can try? І'm not sure what's going on with the
debugging symbols, but it shouldn't be causing the program to crash, right?
Hello Eric,
it is hard to say if I hit your bug or another one, but I managed to
reproduce crash and already reported it to the bug tracker: https://github.com/OSGeo/grass/issues/1024
The problem seems to be with specifying parameter "restrict". If you
really need it, just wait for a fix as it should be quite fast (famous
last words).
Māris.
ceturtd., 2020. g. 15. okt., plkst. 22:11 — lietotājs Eric Patton
(<eric.r.patton@protonmail.com>) rakstīja:
Hi guys,
> gdb v.random
exist
Using native format
0%
My system:
> g.version -re
GRASS 7.8.4 (2020)
libgis revision: 2020-10-13T18:27:00+00:00
libgis date: 2020-10-12T13:00:00-03:00
PROJ: 7.0.0
GDAL/OGR: 3.0.4
GEOS: 3.8.0
SQLite: 3.22.0
> uname -a
Linux L-102377 5.4.0-51-generic #56~18.04.1-Ubuntu SMP Tue Oct 6 09:47:18 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Eric Patton
Marine Geoscience Technologist
Geological Survey of Canada (Atlantic)
Natural Resources Canada
Bedford Institute of Oceanography
1 Challenger Drive, Dartmouth NS, Canada
Hello Eric,
last words).
Māris.
Thanks, Maris, much appreciated. I'll keep an eye on the status of it.
On Fri, Oct 16, 2020 at 2:13 PM Eric Patton
<eric.r.patton@protonmail.com> wrote:
On 20/10/16 12:10PM, Maris Nartiss wrote:
> Hello Eric,
> last words).
> Māris.
Hi Eric,
The ticket has been fixed by Māris and backported (for the upcoming
7.8.5). Can you confirm that it is fixed?
