[GRASS-user] v.rast.stats for just a single statistic, in a python loop
Hello,
I would like to use the v.rast.stats inside a loop in a python script.
The thing is I just need to get one of the nine columns it generates (sum).
As it runs many times in the loop, it takes a lot of (unnecessary, for this script) time and also creates a huge table with too many (unnecessary, for this script) columns.
I was wondering then if there was a way to specify the calculation for just that single statistic.
Also, I wanted to ask you if there is a way to access the source code of a specific module (in this case, v.rast.stats) via web (without downloading the whole source code), just to have a quick look at it (and try to adapt it to my needs, eventually contribute to it if possible, … I don’t know, … just wondering what’s the right way to do it …).
This might be a stupid question, but please take into account that i’m still quite new in all this (fascinating) stuff.
Thank you very much in advance.
Regards
Ismael G.
Ingeniero de Caminos (UPM). Ingénieur des Ponts et Chaussées (ENPC).
PhD researcher @ Urban & Land Planning Department @ ETSICCP UPM www.caminos.upm.es +34 91 336 67 83
On 18/04/12 20:54, Ismael Gómez wrote:
Hello,
v.rast.stats is a script, so fairly easy to modify (see below for accessing it).
http://trac.osgeo.org/grass/browser/grass
For the development version (aka grass7) go to trunk, for other version to branches.
For v.rast.stats in the 6.4 release branch:
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats.
See "Download in other formats" at the bottom for downloading it.
A quick and dirty guess would be that modifying
line 247: BASECOLS="n min max range mean stddev variance cf_var sum"
and
line 368 sed -e '1d' "$STATSTMP" | awk -F "|" '{printf "\nUPDATE '${TABLE}' SET '${col1}' = %i , '${col2}' = %.2f , '${col3}' = %.2f , '${col4}' = %.2f , '${col5}' = %.2f , '${col6}' = %.2f , '${col7}' = %.2f , '${col8}' = %.2f , '${col9}' = %.2f WHERE '${KEYCOL}' = %i;", $2,$3,$4,$5,$6,$7,$8,$9,$10,$1}' > "$SQLTMP"
could actually be enough.
Moritz
Thanks a million, Moritz.
Yours,
Ismael
2012/4/18 Moritz Lennert <mlennert@club.worldonline.be>
Hello,
See “Download in other formats” at the bottom for downloading it.
line 247: BASECOLS=“n min max range mean stddev variance cf_var sum”
and
line 368 sed -e ‘1d’ “$STATSTMP” | awk -F “|” ‘{printf “\nUPDATE ‘${TABLE}’ SET ‘${col1}’ = %i , ‘${col2}’ = %.2f , ‘${col3}’ = %.2f , ‘${col4}’ = %.2f , ‘${col5}’ = %.2f , ‘${col6}’ = %.2f , ‘${col7}’ = %.2f , ‘${col8}’ = %.2f , ‘${col9}’ = %.2f WHERE ‘${KEYCOL}’ = %i;”, $2,$3,$4,$5,$6,$7,$8,$9,$10,$1}’ > “$SQLTMP”
Moritz
Ismael G.
