[GRASS-user] v.rast.stats locks up on wingrass (problem adding columns)
Can I infer from this open ticket that v.rast.stats is currently not
functional within a Windows operating environment?
http://trac.osgeo.org/grass/ticket/1110#comment:2
I am running GRASS 6.4.1 through R 2.13.1 on Windows XP and I need to obtain
cell frequency counts from a categorical raster based on a polygon vector.
If v.rast.stats is out of commission, what other options can people
recommend?
DGann
View this message in context: http://osgeo-org.1803224.n2.nabble.com/v-rast-stats-locks-up-on-wingrass-problem-adding-columns-tp6701826p6701826.html
Please update to 6.4.2, using the latest of the nightly builds [0]
Markus M
[0] http://wingrass.fsv.cvut.cz/grass64/
currently not functional within a Windows operating
environment?
I wouldn't say that for sure. My best advice is to try it for
yourself and see if it works or not. As per the ticket, you
might try it a few times if it fails at first. Please report
your experiences successful or not to the bug report.
can people recommend?
since v.rast.stats is just a shell script combining a number
of other GRASS modules, you could always just run the individual
commands by hand:
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats
The script itself hasn't changed in 7 months.
You might find some other options in the wiki add-ons site.
good luck,
Hamish
My best advice is to try it for yourself and see if it works or not.
I did using 6.4.1 and got the error message reported by others:
C:/GRASS-64-SVN/scripts/v.rast.stats: line 268: v.db.addcol: command not
found
ERROR: Cannot continue (problem adding columns).
since v.rast.stats is just a shell script combining a number of other
GRASS modules, you could always just run the individual commands by hand
I am currently evaluating this as an alternative, though I am also batch
scripting through R and new to GRASS, so... In the meantime...
I updated to the latest nightly build (WinGRASS-6.4.SVN-r47756-1) and
resubmitted my job through R 2.13.1 (using spgrass6), and this time I get
the following error message:
execGRASS("v.rast.stats", flags="verbose",
parameters=list(raster="eosd_resample", vector="mcp80s", colprefix="p80"))
Error in system(cmd0, intern = TRUE) : 'v.rast.stats.exe' not found
Error in parseGRASS(cmd) : v.rast.stats not found
The script is indeed there, but I am not familiar enough with the inner
workings of GRASS to speculate on where the executable comes in.... Has
v.rast.stats been temporarily disabled in WinGRASS or is this something new?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/v-rast-stats-locks-up-on-wingrass-problem-adding-columns-tp6701826p6703669.html
hi,
there seems to be 2 issues here
found
tested with WinGRASS-6.4.SVN-r47756-1-Setup.exe
   v.db.addcol map=mygeology@test columns=helli
   DBMI-DBF driver error:
   ERROR: Fehler beim Ausführen von: 'ALTER TABLE mygeology ADD COLUMN helli
  ERROR: Cannot continue (problem adding column).
so v.db.addcol seems to still have problems with dbf-driver in windows
parameters=list(raster="eosd_resample", vector="mcp80s", >colprefix="p80"))
Error in system(cmd0, intern = TRUE) : 'v.rast.stats.exe' not found <=
I've no experience in using grass within a R session, but there is a wrapper
script
C:\Program Files\GRASS 6.4.SVN\bin\v.rast.stats.bat
and execGRASS() seems to wait for an v.rast.stats.exe which doesn't exist.
best regards
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/v-rast-stats-locks-up-on-wingrass-problem-adding-columns-tp6701826p6703813.html
I'm always doing in the other way in windows: R within a Grass-session
see
http://grass.osgeo.org/wiki/R_statistics#MS_Windows
and there Usage II
or see also
http://lists.osgeo.org/pipermail/grass-stats/2010-September/001274.html
best regards
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/v-rast-stats-locks-up-on-wingrass-problem-adding-columns-tp6701826p6703827.html
