[GRASS-user] v.rast.stats with mode?
Dear list
Is it possible to get the "mode" (most common occurring value) in a polygon for discrete classes? It appears that v.rast.stats does not have this option.
Thanks for a short feedback,
Patrick
On Wed, Mar 16, 2016 at 6:23 AM, patrick s. <patrick_gis@gmx.net> wrote:
Dear list
this option.
v.rast.stats uses r.univar and r.univar doesn't have mode implemented (it's
a TODO in manual). You can look at r.mode but it returns raster map, not
one number.
Anna
Patrick
grass-user mailing list
grass-user@lists.osgeo.org
Thanks, Anna. That helps!
Cheers, Patrick
Dear list
Is it possible to get the “mode” (most common occurring value) in a polygon for discrete classes? It appears that v.rast.stats does not have this option.
v.rast.stats uses r.univar and r.univar doesn’t have mode implemented (it’s a TODO in manual). You can look at r.mode but it returns raster map, not one number.
Anna
Patrick
Following Anna’s suggestion I had to find out that r.mode has to option to handle NULL values, i.e. exclude it from calculation? I need to aggregate rasters to polygons, with rasters covering only a small part of the polygon. As I realized now r.mode returns NULL in such case. Setting NULL with r.null null=9999 it will return 9999 for all of these.
Is there a solution to that problem?
Patrick
Dear list
Anna
Patrick
On Thu, Mar 31, 2016 at 4:32 AM, patrick s. <patrick_gis@gmx.net> wrote:
Following Anna's suggestion I had to find out that r.mode has to option to
I am not sure I understand, is this related to this?
https://lists.osgeo.org/pipermail/grass-dev/2015-October/076654.html
Could you provide more details?
Thanks
Anna
Patrick
Dear list
this option.
number.
Anna
Patrick
I cannot reproduce this issue with grass7. Try the following in the NC demo dataset:
g.region vector=census_wake2000@PERMANENT res=500 -a
v.random -a output=points npoints=5 restrict=census_wake2000@PERMANENT column_type=integer --o
v.kcv map=points@user1 npartitions=3
v.to.rast input=census_wake2000@PERMANENT output=census use=attr attribute_column=ID --o
v.to.rast input=points@user1 output=points use=attr attribute_column=part --o
r.mode base=census@user1 cover=points@user1 output=census_points_rmode --o
The results seem correct: even though there are just 5 points in each census area, and most pixels are thus NULL in the points map, the mode corresponds to 1, 2 or 3.
If you have more NULL cells than others, and you replace the NULL value by an integer value, you will obviously get that value as mode...
Moritz
