[GRASS-user] v.sample value to db column
hej,
is it somehow possible to sample a raster map at given point locations, and put the values directly into a column of the db of the points?
I tried with
v.sample input=segment_points raster=stream_segments column=seg_num
but thats not working...
In following discussion, the same thing is mentioned:
http://wald.intevation.org/tracker/index.php?func=detail&aid=513&group_id=21&atid=205
but is there a simple solution? (I am using GRASS GIS 6.5)
thanks
Johannes
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
On 02/01/2011 05:45 PM, Johannes Radinger wrote:
hej,
v.what.rast
I tried with
thanks
Johannes
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
