[GRASS-user] v.segment, v.lrs.create
Hello everybody,
i'm using grass now for about 3 months now, and i still have some problems with management of vectors and tables.
now i'm trying to create transects with two meter segments. i established the transects along several hightlines with
v.in.ascii 3d lines and v.in.ascii 3d points, but now i don't succeed in establishing the two meter segments.
what is the easiest way (v.segment?, v.lrs.create?, other?)
and how do i use the command, concerning tables and input data?
thanks for your reply
thomas
_____________________________________________________________________
Der WEB.DE SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
http://smartsurfer.web.de/?mc=100071&distributionid=000000000066
Thomas Drüssler wrote on 02/06/2007 09:07 AM:
Hello everybody,
now i'm trying to create transects with two meter segments. i established the transects along several hightlines with v.in.ascii 3d lines and v.in.ascii 3d points, but now i don't succeed in establishing the two meter segments.
Do you have points and lines as two separate vector maps and want to
combine them? Then v.patch and v.clean will be needed.
With an existing line (or several), I simply do:
v.split transects out=transects_split length=2
It inserts vertices every 2 map units (meters in my case).
thomas
Markus,
Do you mean that this should break lines at points locations? I have
tried this once, and it didn't work: v.patch points and lines, v.clean
tool=break didn't break lines at points locations. Or have I
missunderstood your suggestion?
Maciek
Markus,
Mhh, I was hoping for that. Bug or feature?
