What exactly does the disjoint operator do in the GEOS operators of v.select (6.5+) ? It is described as
"disjoint - features do not spatially intersect"
Which sounds pretty much like the reverse of the intersect operator.
However, when I try the following in the nc_spm_06 NC data set:
v.extract input=roadsmajor@PERMANENT output=cary list=1004
v.select -g ainput=roadsmajor@PERMANENT atype=line binput=cary@user1 btype=area output=roads_disjoint_cary operator=disjoint
I get:
http://geog-pc40.ulb.ac.be/grass/misc/disjoint.png
whereas
v.select -r -g ainput=roadsmajor@PERMANENT atype=line binput=cary@user1 btype=area output=roads_reverse_intersect_cary operator=intersects
gives me:
http://geog-pc40.ulb.ac.be/grass/misc/reverse_intersect.png
Is this a bug in the disjoint operator, or am I misinterpreting its meaning ?
Moritz
2009/6/26 Moritz Lennert <mlennert@club.worldonline.be>:
I get:
whereas
gives me:
It's a bug in v.select. Fixed in r38250. Currently `ope=disjoint` =
`-r operator=intersect`. It would be better to change v.select's
algorithm to select features, and to remove this ugly hack.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
On 05/07/09 15:13, Martin Landa wrote:
I get:
whereas
gives me:
Ok, thanks for following up on this. Should we file a bug report for the selection algorithm ? Could you give me more details on the problems with it ?
Moritz
2009/7/7 Moritz Lennert <mlennert@club.worldonline.be>:
the problem is that v.select was originally designed only for
'overlaps' operator. So only features with MBR from B which overlaps
MBR of feature from A are tested. Which is not the case of disjoint
operator.
Martin
