[GRASS-user] v.select output vector is empty
grass-user-request@lists.osgeo.org wrote:
Message: 1
Date: Wed, 29 Oct 2008 11:49:02 -0400
Subject: [GRASS-user] v.select output vector is empty
To: grass-user@lists.osgeo.org
Message-ID:
  <6.2.1.2.2.20081029112204.032837f0@postoffice7.mail.cornell.edu>
Content-Type: text/plain; charset="us-ascii"; format=flowed
Greetings!
I am attempting to execute a "point-in-polygon" process on 2 vectors using
v.select and the output vector is empty, it contains no value/s.
When I create a map display of the 2 vectors I can clearly see the point
intersecting a polygon on the area layer, so it isn't an issue of
no-intersecting
values between the two datasets.
The point vector was created using:
cat /home/kfw4/dev/grass_db/one_point.txt | v.in.ascii out=single_point
fs=',' x=3 y=2 col='batch_id varchar(32),decimal_la double
precision,decimal_lo double precision' --o
v.info and db.select show the correct imported value:
GRASS 6.4.svn (lat_lon):~ > v.info single_point
  | Layer: single_point
  | Mapset: PERMANENT
  | Database: /home/kfw4/dev/grass_db
  | Title:
  | Map scale: 1:1
  | Map format: native
  | Name of creator: kfw4
  | Organization:
  | Type of Map: vector (level: 2)
  | Number of points: 1 Number of areas: 0
  | Number of lines: 0 Number of islands: 0
  | Number of boundaries: 0 Number of faces: 0
  | Number of centroids: 0 Number of kernels: 0
  | Map is 3D: No
  | Number of dblinks: 1
  | Projection: Latitude-Longitude
  | N: 34:06:59.1408N S: 34:06:59.1408N
  | E: 116:04:04.116W W: 116:04:04.116W
  | Digitization threshold: 0
  | Comments:
GRASS 6.4.svn (lat_lon):~ > db.select single_point
cat|batch_id|decimal_la|decimal_lo
1|BAT000000074|34.116428|-116.06781
The area vector was re-projected using v.proj:
  v.proj PREC0101 location=PREC0101 mapset=PERMANENT
GRASS 6.4.svn (lat_lon):~ > v.info PREC0101
  | Layer: PREC0101
  | Mapset: PERMANENT
  | Title:
  | Map scale: 1:1
  | Organization:
  | Source date: Wed Oct 29 09:15:47 2008
  | Number of points: 0 Number of areas: 6720
  | Number of lines: 0 Number of islands: 1212
  | Number of boundaries: 13970 Number of faces: 0
  | Map is 3D: No
  | N: 49:25:31.535591N S: 24:27:48.66742N
  | E: 66:54:50.339466W W: 124:46:59.356755W
  | Comments:
Clearly, the single_point projection is contained by the PREC0101
projection. (Clearly?)
Yet, v.select yields nothing.
GRASS 6.4.svn (lat_lon):~ > v.select ainput=single_point binput=PREC0101
output=single_select op=overlap --overwrite --v
WARNING: Vector map <single_select> already exists and will be overwritten
Processing ainput lines ...
  100%
Processing ainput areas ...
Writing attributes ...
Layer 1
v.select complete.
Building topology for vector map <single_select>...
0 primitives registered
0 vertices registered
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built
Number of nodes : 0
Number of primitives: 0
Number of points : 0
Number of lines : 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
GRASS 6.4.svn (lat_lon):~ > v.db.select -c single_select
Any suggestions?
Thank you.
KFW
Two thoughts.
1) Try telling Grass-GIS explicitly that ainput is a point and binput is
an area. I know these are supposed to be optional...
2) Use v.distance to see if the point's distance to the area is
calculated correctly (if the point is inside the area, distance should
be zero)
Richard Chirgwin
Message: 2
Date: Wed, 29 Oct 2008 13:46:29 -0400
Subject: RE: [GRASS-user] Tips for setting up an new
  FOSS-GEO-linux-box
To: "Nikos Alexandris" <nikos.alexandris@felis.uni-freiburg.de>,
  "grass-user" <grass-user@lists.osgeo.org>
Message-ID:
  <1715AFFECC318F4995A52EEE622FC30106385D@s0-ott-x4.nrn.nrcan.gc.ca>
Content-Type: text/plain; charset="iso-8859-1"
OS:
OK, I think I shouldn't ask about which OS since foss runs on everything
(right?). But are I am curious to know if there are any advantages using
Debian instead of Ubuntu for example?
Everyone has their own favorite; I've been using Ubuntu and Grass together
since 2004, with no difficulties on 32-bit and 64-bit machines.
Filesystems:
Which filesystem is better(=safer/faster) for data storage? Is there any
important advantage to choose XFS for example rather than ext3?
Not sure about the main differences/advantages of either; I've been using ext3
since forever, with no regrets.
Partitions:
Do you keep your geo-data in a separate partition? I suppose yes. Have
you split further your partition based on other criteria, always related
with "working with geospatial data"?
Pretty much the main 3-4 projects I'm working on are on /home, with anything I
haven't worked on in the last 2-weeks backed up and archived on an external
2TB hardrive. (LaCie)
Do you keep all of your source code in a separate partition maybe?
Nope, just under good old /usr/local. I only compile from scratch those applications where
I need all the bleeding edge goodies and bug fixes, which, for me, is only Grass,
gdal, and lilypond. I try to use the distribution's packages for everything else;
makes it a lot easier to maintain using the package manager than chasing around
and recompiling source for a ton of apps.
Organisation:
GRASS takes care to organise the data inside the GIS data-base and its
fantastic. But what about the "raw" data? How do you organise them?
Manually everything? Any tool to be more productive?
Once raw data is imported into Grass, I usually get it off my hard drive and backed
up onto something external, in case my computer melts down; then I can always
rebuild from scratch. Of course the external drive could also melt down. I guess
a RAID would be even better, but costs more.
BackUp:
How often do you backup your data? Do you just copy or do you compress
as well? What is safer?
I've been using 'tar cjvf' for each project, but that is becoming unmanageable; I need
to migrate to a versioning system as Dylan has done with rsync. At least for the
projects I work on all the time. The old stuff can probably stay on the backup drive
in tar.bz2 format.
Other:
Any other important issues when setting-up a new foss-geo-box?
I just installed Ubuntu Intrepid 8.10 yesterday, and found it much easier
installing packages via Synaptic rather than downloading the bleeding edge
source packages and compiling. The only source package I had to compile was
Grass.
Thank you, Nikos
P.S. Maybe we can add a new wiki-page if something useful comes out of
this thread. Or maybe not... :slight_smile:
grass-user mailing list
Message: 3
Date: Wed, 29 Oct 2008 20:29:23 +0100
Subject: Re: [GRASS-user] Tips for setting up an new
  FOSS-GEO-linux-box
Cc: grass-user <grass-user@lists.osgeo.org>
Message-ID:
  <86782b610810291229s4b92e79ch25713012075df505@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
On Wed, Oct 29, 2008 at 6:46 PM, Patton, Eric <epatton@nrcan.gc.ca> wrote:
OS:
Happy Mandriva user here :slight_smile:
Also Scientific Linux user on our cluster.
I don't even install but run it directly with a link from
grass64/dist.x86_64-unknown-linux-gnu/
Message: 4
Date: Wed, 29 Oct 2008 20:34:59 +0100
From: Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>
  FOSS-GEO-linux-box
To: grass-user <grass-user@lists.osgeo.org>
Message-ID: <1225308899.14612.4.camel@vertical>
On Wed, 2008-10-29 at 15:08 +0100, Nikos Alexandris wrote:
I know, I know... it's off the lists topic! But I need some help.
Probably I am going to "migrate" soon all of my stuff in a new
linux-box. So I would like to collect best practice tips concerning the
following:
OS:
Filesystems:
Partitions:
Organisation:
BackUp:
Other:
Thank you, Nikos
Dylan, Eric and Markus,
thank you for your precious time to respond.
Since there are already 3 answers then maybe some wiki-page can be
set-up out-of it. I'll try to structure the information a bit and open a
page whenever I find some free-time (possibly this weekend).
Please to all GRASS-users following the list, if you have some spare
time and consider these questions important, participate with your
ideas/tips/hints/tricks.
Kind regards, Nikos
Message: 5
Date: Wed, 29 Oct 2008 21:03:56 +0000
Subject: Re: [GRASS-user] d.out.file now does GeoTIFFs
To: hamish_b@yahoo.com
Cc: grass list <grass-user@lists.osgeo.org>
Message-ID: <18696.53180.114643.321976@cerise.gclements.plus.com>
Content-Type: text/plain; charset=us-ascii
Hamish wrote:
Unfortunately 'd.info -g' is buggy, it reports exactly the same as
'g.region -g'. But if that was fixed it would be an easy solution.
fixed in devbr6 but not trunk; I'm unsure about the changes needed.
7.0 doesn't have D_get_screen_window(); D_setup() uses R_get_window()
instead (R_get_window() reports the raster clip region, which is
initially set from $GRASS_FRAME).
Also, I would suggest reporting the values returned from D_get_u_*
rather than using the current region directly (which can always be
obtained from g.region).
Although the two should match, it's the values reported by D_get_u_*
which are actually used, so using D_get_u_* would be more robust in
the face of any future extensions (e.g. allowing the region to be
enlarged to fit the window rather than shrinking the window to fit the
region).
