[GRASS-user] v.select question
Dear Grass'ers
I have a question regarding v.select. My data consists of vector polygons and sample plots randomly positioned both inside and outside the vector polygons. I would like to select only those sample plots that are within the vector polygons, unfortunately v.select selects those sample plots within the polygons and those which overlap or come into contact with polygon boundary. I would like to select sample plots that are within the polygon and do not touch / overlap with the boundary.
I am using version 6.2.3 and the only option I have in v.select is overlap.
Is there another tool I could use to clip / refine my sample plot selection?
Many thanks,
Wesley
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean. MailScanner thanks Transtec Computers for their support.
with the boundary.
v.overlay is much more powerful, perhaps it can help.
maybe you could select areas touching polygon boundary features and then
v.overlay "not" them away from the culled version you already have.
note it will only work on features with cat numbers, so you'll have to give boundaries can numbs with v.category first. usually they don't have them.
Hamish
