[GRASS-user] v.split length=? in latlon
in v.split:
I wonder what units are be used as length in a lat-lon environment?
Are these degrees?
Why isn't there an option for m, km,..?
Thanks in advance,
Achim
On Fri, May 21, 2010 at 6:59 PM, Achim Kisseler
<ak7@jupiter.uni-freiburg.de> wrote:
in v.split:
Are these degrees?
I am afraid yes since it uses Vect_line_length(). Certainly this is
rather useless.
The doxygen documentation for that function suggests:
   "For Lat-Long use Vect_line_geodesic_length() instead."
The "easiest" way would be to manage things as done in v.distance.
Please open an enhancement report in trac for this.
Am 24.05.2010 23:35, schrieb Markus Neteler:
I'll do.
Thanks for response, Markus!
Achim
