[GRASS-user] v.surf.idw
Dear list,
I got the following message when v.surf.idw used with DGM vector points :
v.surf.idw:
15984 data sets selected from table.
0 points loaded.
v.surf.idw: no data points found.
Input-Layer: Shape (Point)
count of interpolation points:default (12)
column: elevation points
First, I did the v.db.connect command to link with the dbf attribute table.
Do you have any suggestions?
Regards
Chris
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
v.surf.idw:
0 points loaded.
are all the points outside the current region?
Does "d.vect points_map" show them?
What if you run "g.region vect=points_map" first? (then "g.region -p"
and check the resolution and rows/cols aren't more than ~ 5000x5000)
Hamish
      ____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
