[GRASS-user] v.surf.spline
I tried to make an interpolation of a vector contour map by using r.surf.spline, but i got this error:
ERROR: No raster or vector or cross-validation output​
It may depends on the input data?
On Thu, Jan 22, 2015 at 7:15 AM, DEBERNARDI DANILO <
I assume you are talking about v.surf.bspline.
The error message suggests that you didn't provide the name of the output
map. You probably want raster output, so please specify it (either in
command line or GUI dialog). The particular option differs in GRASS64 and
GRASS7 so please look at the manuals:
http://grass.osgeo.org/grass64/manuals/v.surf.bspline.html
http://grass.osgeo.org/grass70/manuals/v.surf.bspline.html
If you have contour lines, check also r.surf.contour :
http://grass.osgeo.org/grass70/manuals/r.surf.contour.html
Best,
Anna
grass-user mailing list
grass-user@lists.osgeo.org
