[GRASS-user] v.to.3d -r option not working properly
Hello,
I imported a GMT multisegment ASCII file with contour lines using v.in.ogr,
resulting in 3D vector file. Then I wanted to transform the z-coordinate to
an attribute column using
v.to.3d -r input=contour_3d col="CONC" output=contour_2d
(I added CONC column to contour_3d before, using v.db.addcol map=contour_3d
columns="CONC double precision").
However, the resulting contour_2d column CONC remains empty. No error is
reported.
I am sure contour_3d contains correct Z-values (I transformed it to raster
to see).
Does anyone know what I am doing wrong, please?
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-to-3d-r-option-not-working-properly-tp5211241.html
On Tue, Jun 16, 2015 at 9:42 AM, JanaKr <jkrajc@gmail.com> wrote:
Hello,
v.to.3d -r input=contour_3d col=“CONC” output=contour_2d
columns=“CONC double precision”).
reported.
to see).
nothing, it just was not implemented for lines, since 3D lines can have vertices of different heights, but we can upload only one value. However, since it makes perfectly sense for contours, I added the support for lines there (r65493). Any chance you are using GRASS 7.1 (trunk) to try it out?
Anna
grass-user mailing list
grass-user@lists.osgeo.org
On Wed, Jun 17, 2015 at 2:57 AM, Jana Krajcovicova <jkrajc@gmail.com> wrote:
No, I am using GRASS 6.4.
So it is only newly implemented in 7.1?
Yes, since yesterday. What operating system do you use? For Windows, there
are daily builds available and for Ubuntu there is a PPA. The change might
not be in today's binaries, probably tomorrow.
Anna
Jana
On Wed, Jun 17, 2015 at 4:33 AM, Anna Petrášová <kratochanna@gmail.com>
wrote:
Hello,
v.in.ogr,
to
map=contour_3d
reported.
raster
to see).
Anna
Hi Anna,
It is not possible to avoid this procedure, of creating the new column in the layer of origin (3d layer), to get the height column in the 2d layer? Something like the ‘column’ parameter of v.random (Name of column for z values; Writes z values to column), where we just give a name to the height column in the resulting layer?
Will this be backported to 7.0.x?
Thank you very much!
Best regards!
Pedro
reported.
On Tue, Oct 20, 2015 at 6:41 PM, Pedro Venâncio <pedrongvenancio@gmail.com>
wrote:
Hi Anna,
map=contour_3d
reported.
Something like the 'column' parameter of v.random (Name of column for z
I believe I backported it, 7.0.2 RC1 release is just going on now, there
will be an announcement soon.
Anna
Best regards!
Pedro
Hi Anna,
Thanks, I will check!
What do you think about this workflow?
Thanks!
Pedro
I believe I backported it, 7.0.2 RC1 release is just going on now, there will be an announcement soon.
reported.
On Wed, Oct 21, 2015 at 4:15 AM, Pedro Venâncio <pedrongvenancio@gmail.com>
wrote:
Hi Anna,
map=contour_3d
is
reported.
layer? Something like the 'column' parameter of v.random (Name of column
I think how it currently works, doesn't make sense for the reverse case,
please create a ticket. The column should be created in the new vector.
Thanks!
Pedro
Done: https://trac.osgeo.org/grass/ticket/2774
Thanks!
Pedro
