[GRASS-user] v.to.db area calculations
Hello,
I’m trying to calculate the area of a polygon using v.to.db as follows (through R):
execGRASS(“v.to.db”, flags = c(“p”,“quiet”), parameters = list(map = “test”, units = “meters”, option = “area”, separator = “comma”),intern = TRUE)
I assume that the output of this command will be a meters squared calculation of the area inside the polygon ‘test’.
However, in QGIS, I manually calculated the area the they do not match. QGIS (which I believe to be true) shows 0.128m2, and the output from v.to.db shows 22.42226m2.
I am working in WGS84.
Can anyone shed some light on how v.to.db calculates area and why it might be going wrong please?
Thank you
James
James Duffy
PhD Researcher
Environment and Sustainability Institute
Penryn Campus
University of Exeter
Penryn
Cornwall
TR10 9FE
Hi James,
QGIS uses a ellipsoidal area measurement, while GRASS (like most of the other GIS) uses a Cartesian measurement (others, please correct me if that is not the case in WGS84).
See amongst others:
https://issues.qgis.org/issues/12057 and
https://issues.qgis.org/issues/14675
Would you mind comparing area measurement of a third software (SAGA, PostGIS, ...)?
Stefan
________________________________________
Von: grass-user [grass-user-bounces@lists.osgeo.org] im Auftrag von James Duffy [james.philip.duffy@gmail.com]
Gesendet: Donnerstag, 18. Mai 2017 16:22
An: grass-user
Betreff: [GRASS-user] v.to.db area calculations
Hello,
I'm trying to calculate the area of a polygon using v.to.db as follows (through R):
execGRASS("v.to.db", flags = c("p","quiet"), parameters = list(map = "test", units = "meters", option = "area", separator = "comma"),intern = TRUE)
I assume that the output of this command will be a meters squared calculation of the area inside the polygon 'test'.
Thank you
James
James Duffy
PhD Researcher
Penryn Campus
Penryn
Cornwall
TR10 9FE
On 18/05/17 18:41, Blumentrath, Stefan wrote:
Hi James,
See amongst others:
I would suggest making tests with polygons of which you know the area (e.g. simple squares to begin with)
Moritz
Hello,
Thanks for the reply. I don’t have SAGA or PostGIS set up at the moment. (have sent Stefan the shapefile off-list).
Moritz - I know that the QGIS value is true. The polygon has been drawn over a feature on a raster image (which I know is correct in its dimensions).
Thanks
James
On 19 May 2017 at 08:36, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hi James,
See amongst others:
Would you mind comparing area measurement of a third software (SAGA, PostGIS, …)?
Moritz
James Duffy
PhD Researcher
Penryn Campus
Penryn
Cornwall
TR10 9FE
Just checked the data you send offline in QGIS 2.18.0.
With your sample data
SAGA (through processing) returns an area of 0.0000…
QGIS with OTF ON: 34,815 m²
QGIS with OTF OFF: 0,127 m²
Stefan
Le 19 mai 2017 10:19:06 GMT+02:00, "Blumentrath, Stefan" <Stefan.Blumentrath@nina.no> a écrit :
In what projection is the original data ?
Moritz
Stefan
Output from ogrinfo:
INFO: Open of `C:\Sandbox\RGRASS\DATA\training_single.shp’
On 19 May 2017 at 09:38, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Le 19 mai 2017 10:19:06 GMT+02:00, “Blumentrath, Stefan” <Stefan.Blumentrath@nina.no> a écrit :
Moritz
Stefan
James Duffy
PhD Researcher
Penryn Campus
Penryn
Cornwall
TR10 9FE
Le 19 mai 2017 10:41:29 GMT+02:00, James Duffy <james.philip.duffy@gmail.com> a écrit :
INFO: Open of `C:\Sandbox\RGRASS\DATA\training_single.shp'
     using driver `ESRI Shapefile' successful.
Layer name: training_single
Metadata:
DBF_DATE_LAST_UPDATE=2017-05-17
Geometry: Polygon
Feature Count: 1
Extent: (73.213474, 0.225604) - (73.213477, 0.225608)
Layer SRS WKT:
GEOGCS["WGS 84",
   DATUM["WGS_1984",
       SPHEROID["WGS 84",6378137,298.257223563,
           AUTHORITY["EPSG","7030"]],
       AUTHORITY["EPSG","6326"]],
   PRIMEM["Greenwich",0,
       AUTHORITY["EPSG","8901"]],
   UNIT["degree",0.0174532925199433,
       AUTHORITY["EPSG","9122"]],
   AUTHORITY["EPSG","4326"]]
Ok, so the data is in degrees and 0.127 is not in m2, but in degree2 which is not a really useful unit as its meaning on the ground depends on the latitude.
Moritz
Moritz
>Cheers,
>Stefan
On Thu, May 18, 2017 at 4:22 PM, James Duffy <james.philip.duffy@gmail.com> wrote:
Hello,
This is a large difference. Is it possible that several polygons share the same category? In this case the entry in the attribute table is the sum of all polygons with that category.
GRASS uses geodesic distance and area calculation for latlon, I believe QGIS as well.
Markus M
Thank you
James
James Duffy
PhD Researcher
Penryn Campus
Penryn
Cornwall
TR10 9FE
grass-user mailing list
grass-user@lists.osgeo.org
Le 19 mai 2017 11:12:30 GMT+02:00, Markus Metz <markus.metz.giswork@gmail.com> a écrit :
wrote:
Hello,
follows
(through R):
TRUE)
match.
the
of
QGIS as well.
QGIS only uses geodesic when OTF projection is activated and a datum is selected in the project properties (done by default with otf active I think). Otherwise it uses map units.
Moritz
Markus M
Thank you
James
James Duffy
PhD Researcher
Penryn Campus
Penryn
Cornwall
TR10 9FE
Just to clear a few things up.
The shapefile contains only a single polygon (I created it as a simple test to work out this discrepancy).
OTF is turned off in QGIS, I am working in EPSG 4326.
The 0.127m2 comes from using the Measure tool (OTF off) in QGIS. And it is set to display m2.
Using the $area calculator in the field calculator in QGIS does indeed show something that is more likely degrees squared.
On 19 May 2017 at 10:20, Moritz Lennert <mlennert@club.worldonline.be> wrote:
wrote:
Hello,
follows
(through R):
TRUE)
match.
the
of
QGIS as well.
Moritz
Markus M
Thank you
James
James Duffy
PhD Researcher
Penryn Campus
Penryn
Cornwall
TR10 9FE
James Duffy
PhD Researcher
Penryn Campus
Penryn
Cornwall
TR10 9FE
Below some results from quick tests.
Summary: personally I would trust GRASS GIS a bit more, but I'm biaised...
Test 1:
GRASS trunk in NC demo location (EPSG 3358)
g.region n=200100 s=200000 w=500000 e=500100 -ap
v.in.region out=nc_testpolygon
v.to.db -p nc_testpolygon op=area --q
1|10000
GRASS trunk in EPSG 4326 location
v.proj location=nc_spm_08 mapset=user1 input=nc_testpolygon
1|10002.503642603
v.out.ogr nc_testpolygon out=nc_testpolygon.shp (i.e. shapefile is in degress, EPSG 4326)
QGIS (using the exported shapefile)
No OTF
measuring tool: 12.324,737 m²
$area in calculator: 12320.2346026
OTF to EPSG 4326, with datum WGS84
measuring tool: 10.072,355 m²
$area in calculator: 10046.3679510
Test 2:
GRASS trunk, in ESPG 4326 location
g.region n=74 s=73 w=0 e=1 res=1 -p
v.in.region region_1degree_73_74N
v.to.db -p region_1degree_73_74N op=area --q
1|3539348689.40454
v.out.ogr region_1degree_73_74N out=region_1degree_73_74N.shp
GRASS trunk in EPSG 3575 location
v.proj location=LL_WGS84 mapset=mlennert input=region_1degree_73_74N
1|3539337483.97153
no OTF projection
measuring tool 1,002 m² (sic)
export geometry column: 1
$area in calculator 12392029030.5000000
with OTF projection, datum for measurements WGS84
measuring tool 3.503.322.774,337 m²
$area in calculator: 3499702798.3400998
reproject to EPSG 3575
with OTF, datum WGS84
export geometry column 3539169026.18628
export geoemtry column (column named otf) 3499702798.00000
$area in calculator: 3499702798.6579294
Hello,
Thank you for your investigations.
Is there anything else I can do about this? I trust my QGIS measurement because I know the size of the object I have drawn around. However I would really like to use GRASS to automate my workflow…
Thanks
James
On 19 May 2017 at 13:41, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Summary: personally I would trust GRASS GIS a bit more, but I’m biaised…
Test 1:
1|10000
1|10002.503642603
No OTF
Test 2:
1|3539348689.40454
1|3539337483.97153
no OTF projection
James Duffy
PhD Researcher
Penryn Campus
Penryn
Cornwall
TR10 9FE
On 24/05/17 11:06, James Duffy wrote:
Hello,
But as you say below:
        And it
As I showed with my test, the value of 0.127m2 is probably wrong. In the case of the 10000m2 rectangle, I get an error of over 2000m2 with OTF off on an EPSG 4326 ! Only with OTF on, I get a result closer to the true size.
Would you be willing to share your test polygon ?
Moritz
However I
would really like to use GRASS to automate my workflow...
Thanks
James
        simple
        And it
        indeed
    biaised...
    Test 1:
    1|10000
    1|10002.503642603
    No OTF
    Test 2:
    1|3539348689.40454
    1|3539337483.97153
    no OTF projection
    $area in calculator 12392029030 <tel:12392029030>.5000000
*James Duffy*
PhD Researcher
Penryn Campus
Penryn
Cornwall
TR10 9FE
