temiz wrote:
?? I am sorry. But, how can I establish relation between new categories and
the table's category. Aren't they so different ?
Temiz,
What do you mean by "table's category"?
to clarify my question:
I produced point vector from topographic contour maps.
I tried to upload x,y coords and elevation value.
But
v.to.db does not use unique cat value of point map generated from
v.to.points (1st layer's cat values are not unique.)
Is there any way to create new map from a map generated from
v.to.points, which has one layer,unique cats, and
any field wanted ? or any other way you think ?
OK. So you want to transfer an attribute from the v.to.points output's
layer 1 table into the layer 2 table, where each point has a unique
category. You also want to store points' x,y coords in the layer 2
table. Then you can do it like this:
# v.to.points, as you used it:
v.to.points input=e30a2top type=point,line,boundary,centroid
output=nokta1 llayer=1 dmax=100
# add x,y,z columns to layer 2 of the v.to.points output:
v.db.addcol nokta1 layer=2 col="x double, y double, z double"
# *assuming* the column name where the attribute is stored is "height"
# (replace it accordingly), to transfer it into nokta1 layer's 2 "z"
# column, do:
v.to.db map=nokta1 type=point option=query qlayer=1 qcolumn=height
layer=2 column=z
# now upload x,y coordinates:
v.to.db map=nokta1 type=point option=coor layer=2 column=x,y
As result, your nokta1 vector has two layers, with x,y,z values stored
in layer 2, where each point has a unique category.
Does that help?
Maciek
