[GRASS-user] v.to.points doesn't create a point layer?
I was using v.what.rast and I got an error that no point layer was found.
the layer that was passed was created using v.to.points from a vector file.
The v.to.points creates two tables in SQLite and I didn’t like it. I exported it to a geo package format and then imported it as the point layer I wanted to see.(is there another way, please let me know)
I tried v.what.rast and I experienced the same error that a point layer can’t be found on both point layers.This is the v.what.rast command that generates an error:
v.what.rast --verbose map=POM@Mehrdad raster=ABC@Mehrdad column=ABC
The error is:
Reading features from vector map…
No features of type (point) found in vector map POM@Mehrdad
questions:
  • Do you know a way that v.to.points creates only one table in SQLite?
  • Why I get the error in v.what.rast? I have looked at the POM and it is really a points layer (it appears like that in GRASS)
Thanks for your help,
Mehrdad
Mehrdad Varedi
On 10/21/18 7:37 AM, Mehrdad Varedi wrote:
What was the input to v.to.points? The two tables in sqlite result from the way that v.to.points works: it creates 2 “layers” attached to the output points vector: layer 1 with the categories of the original lines (or boundaries) and layer 2 with new individual categories for each point.
So when you go to the next step, v.what.rast, you probably want to specify “layer=2”
The error is:
questions:
First guess: have you set the computational region to the ABC raster?? (FAQ # 0 in GRASS)
Please post the outputs from:
g.region -p
r.info ABC
v.info POM
Mehrdad
Mehrdad Varedi
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
Great! Thank you Micha,
I had reset the region and forgot to set it properly. Thanks for your help.
The team here are all amazing! Good work and I hope someday I could compensate so much support :slight_smile:
M.
Mehrdad Varedi
