[GRASS-user] v.to.points: extract start/end nodes
I need to extract start or end nodes of lines into two separated
output maps. Unfortunately `v.to.points` doesn't seems to support it
(only `nodes` or `vertices` can be chosen). I am thinking to add such
functionality to `v.to.points`. But before that, it can be that I am
overlooking another tool which I am looking for?
Thanks for pointers in advance, Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On 15/03/19 14:03, Martin Landa wrote:
v.to.db with options start/end provides the coordinates of these points.
Moritz
pá 15. 3. 2019 v 15:01 odesílatel Moritz Lennert
<mlennert@club.worldonline.be> napsal:
thanks, I overlooked `v.to.db`. Anyway I would still need to hack
around since `v.to.db` does not create a new output vector map. So
it's still make sense to me to implement this functionality in
`v.to.points`.
Ma
Martin Landa
On 15/03/2019 22:45, Martin Landa wrote:
[<mlennert@club.worldonline.be>](mailto:mlennert@club.worldonline.be) napsal:
`v.to.points`.
Ma
Whenever we get new Lidar data, I run a script to extract the streamlines network, then obtain the upstream flow accumulation area for both ends of each stream reach. The script uses a combination of v.db.update to get the x,y coordinates of both ends of each stream reach. Then these coordinates are extracted and piped into v.in.ascii, creating a new points vector. Next I get the upstream contributing area from the flow accumulation raster (v.what.rast). Finally an sql expression is constructed for db.execute to update the streams vector with upstream area for each reach from the end points vector.
So, for me, an option in v.to.points to get the start and end points would help to simplify this workflow.
Cheers, Micha
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
so 16. 3. 2019 v 13:28 odesílatel Micha Silver <tsvibar@gmail.com> napsal:
done in r74283 (trunk), will be included in 7.8 release. I also find
strange that `dmax` option has defined default value (100 of map
units), could be changed in G8 see [1].
Ma
Martin Landa
