I need to convert a vector contour map to a raster so I can apply the
hydrologic models modules.
Reading the v.to.rast manual page I learned that I needed to add categories
to the input contour map. Running v.category added no categories: "0
features added."
v.info does not tell me anything about the elevation values of the contour
lines. Looking at the v.* modules, and trying v.univar, didn't help. I could
try v.to.3d, but I need information about the vector map's contents.
Which v.db* should I use to find the elevation colum associated with each
contour line?
TIA,
Rich
contour line?
Long ago I used the GUI and it had a menu to examine the vector map's table.
Now, I just leared that v.db.select will work. There're more columns than I
need, but one does have the elevation data. Back to work ...
Rich
I think you need to interpolate and not simply convert vector lines to
raster lines. Make sure lines have an attribute with elevation (or z
coordinate) and use e.g. v.surf.rst module.
Māris.
trešd., 2023. g. 10. maijs, plkst. 17:29 — lietotājs Rich Shepard
(<rshepard@appl-ecosys.com>) rakstīja:
features added."
contour line?
TIA,
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Māris.
Interpolating the vector contour file before rasterizing makes sense to me,
too. Never before having to convert a vector elevation contour file to a
raster file I'd no idea which v.surf.* module to apply.
The vector file has a ContourEle attribute with the elevation values.
I'm taking your advice and will use v.surf.rast.
This project has more topography data issues than any I've encountered since
I started using grass with version 4.0 (all integer, all CLI.)
Very much appreciated,
Rich
In addition, here is an overview page:
https://grasswiki.osgeo.org/wiki/Interpolation
Māris.
> features added."
> contour line?
> TIA,
> Rich
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
Markus,
Thanks very much. I'm learning many new things on this project and still
need to meet regulator's deadlines.
Much appreciated,
Rich
Markus,
The wiki page on 'Contour lines to DEM' is what I need.
Best regards,
Rich
