[GRASS-user] v.to.rast densify option gives null output
When I use the -d flag in v.to.rast, cells output are null. Omitting the -d
flag works fine for rasterization with default thin lines.
Not sure how to resolve. Is there an alternative GRASS module that can do
the same?
Richard
GRASS GIS 7.0 svn / rev 57721 / python 2.7.3
Mint Linux / Ubuntu Precise
Example of output:
v.to.rast -d --overwrite input=waterways_finaledit@PERMANENT type=area
output=waterways_finaledit_vtr_dense use=val value=5
Pass 1 of 3:
Reading areas...
Reading features...
Writing raster map...
Pass 2 of 3:
Reading areas...
Pass 3 of 3:
Reading areas...
Converted areas: 8415 of 13694
v.to.rast complete.
Type of Map: raster Number of Categories: 0 |
| Data Type: CELL
| Rows: 11319
| Columns: 7737
| Total Cells: 87575103
| Projection: UTM (zone 47)
| N: 2379330 S: 1360620 Res: 90
| E: 971010 W: 274680 Res: 90
| Range of data: min = NULL max = NULL
| Data Source:
| Vector Map: waterways_finaledit@PERMANENT
| Original scale from vector map: 1:1
| Data Description:
| generated by v.to.rast
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-to-rast-densify-option-gives-null-output-tp5105039.html
On Fri, Feb 21, 2014 at 10:49 AM, RichardCooper <richtcooper@hotmail.com> wrote:
The -d option of v.to.rast works only for lines, not for boundaries.
You would need to convert the boundaries to lines and then use
v.to.rast type=line -d.
Markus M
the same?
Richard
Example of output:
Pass 1 of 3:
Reading areas...
Reading features...
Pass 2 of 3:
Reading areas...
Pass 3 of 3:
Reading areas...
v.to.rast complete.
| Data Type: CELL
| Rows: 11319
| Columns: 7737
| Data Source:
| Data Description:
grass-user mailing list
grass-user@lists.osgeo.org
Thanks. I converted to lines, added categories and rasterized:
v.type input=waterways_finaledit@PERMANENT output=waterways_finaledit_lines
from_type=boundary to_type=line
v.category input=waterways_finaledit_lines@PERMANENT type=line
output=waterways_finaledit_lines_catadd option=add
v.to.rast -d --overwrite --verbose
input=waterways_finaledit_lines_catadd@PERMANENT type=line
output=waterways_finaledit_lines_catadd_vtr_dense use=val value=5
Richard
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-to-rast-densify-option-gives-null-output-tp5105039p5105061.html
