[GRASS-user] v.to.rast error
I would like to rasterize a vector layer. I tried :
v.to.rast input=clc_2000_centre layer=1 output=clc_2000_centre use=attr
column=CODE_00 value=1 rows=4096 (using the GUI).
I got this error :
Column type not supported by db_select_to_array()
The data of this column is integer, eg : 123, 234, 623, ...
Do you have an idea ? Thanks,
Y.
Yves Jacolin
http://yjacolin.gloobe.org
Stagiaire Conservatoire Régional des Espaces Naturels de la région Centre
http://cahiersnaturalistes.free.fr/cpnrc/
Ok, I know why I get this error (char type). What I don't understand is why my
column is in char type ?
If I want to change this, do I need to use db.execute to create a new column
and then copy data from the first column to the new one ?
Thank you for your tips !
Y.
Le Lundi 31 Juillet 2006 10:41, Jacolin Yves a écrit :
I got this error :
Y.
Yves Jacolin
- Qu'est-ce que cela peut faire que je lutte pour la mauvaise cause
puisque je suis de bonne foi?
- Et qu'est-ce que ça peut faire que je sois de mauvaise foi
puisque c'est pour la bonne cause. (Jacques Prévert)
Jacolin Yves wrote on 07/31/2006 11:03 AM:
This was defined during import and depends on the data source.
Could you post:
v.info -c clc_2000_centre
Right.
Y.
I got this error :
Y.
Thank you for your reply, my column was indeed a char type. I changed this in
the dbf sourcefile (easier for me) and imported it again in grass.
Thank you.
Y.
> why my column is in char type ?
Could you post:
> column and then copy data from the first column to the new one ?
Right.
> Y.
>> Hi,
>> I got this error :
>> Y.
grassuser mailing list
grassuser@grass.itc.it
Yves Jacolin
