[GRASS-user] v.transform - output messages
hi maciej,
i will try to reproduce it with SPEARFISH 6.0, but it could take time a little bit ...
greetings
helli
Von: Maciej Sieczka <tutey@o2.pl>
Gesendet: 15.10.06 14:09:27
An: Helmut Kudrnovsky <hellik@web.de>
CC: grassuser@grass.itc.it
Betreff: Re: [GRASS-user] v.transform - output messages
Helmut Kudrnovsky wrote:
i want to move a large polygon-layer by "v.transform " with the following options:
v.transform
input=schiechtl_stern_m28
output=fwoe_mm28_tf45
xshift=-450000.0
yshift=0.0
zshift=0.0
xscale=1.0
yscale=1.0
zscale=1.0
zrot=0.0
so a -450000m-shift on the x-axis,
when i start, i get the following
output-messages:
V_ask error: Illegal row (40) in call to V_const
what do this messages mean?
I don't know but it's not normal I would say. If you could reproduce
that with sperfish60 and submit a bug report with how to reproduce
instruction it could incline some Grass developer to fix it. Could you?
p.s. is there something similar like v.transform for raster data to move/shift raster data inside grass?
r.region. But it's not that straight-forward as v.transform - you have
to manually calculate the region bounds (N,S,E,W) given the shift you
need, then apply this new region bounds to your raster.
Maciek
______________________________________________________________________
XXL-Speicher, PC-Virenschutz, Spartarife & mehr: Nur im WEB.DE Club!
Jetzt gratis testen! http://freemail.web.de/home/landingpad/?mc=021130
