Hi all!
I've found that values of transformation matrix reported by
v.transform are erroneous after using this values in ST_Affine (a
PostGIS's function).
The values that seems to be erroneous are x_offset and y_offset. The
rotation values seems to are fine.
The transformed elements are ok (it is, their coordinates are in the
right place).
Values reported by v.transform:
xoff = -139153.031250
yoff = 8352534.450195
The correct values must be (aproximately):
xoff = 5461371
yoff = 6321181
The complete session's log with one test element is there (same
results with a whole layer):
http://pastebin.com/FUtnePvb
Local map: tmp
Transformed map: tmp_geo
Take a look at the map region for tmp/tmp_geo (reported by v.info),
and compare these values with those of x_off / y_off (reported by
v.transform).
Maybe I'm not interpreting this correctly.
Thanks all!
Jose
On Tue, Feb 26, 2013 at 2:17 PM, José María Michia Roberts
<jose.maria.michia@gmail.com> wrote:
Hi all!
right place).
xoff = 5461371
yoff = 6321181
Local map: tmp
v.transform).
Note that there are two transformation matrices, one for forward
transformation, one for backward transformation. Can the PostGIS
ST_Affine function print both matrices?
If possible, rather use v.rectify in GRASS 7 instead of v.transform in GRASS 6.
With a recent version of GDAL/OGR, you can also add GCPs to a
datasource with ogr2ogr -gcp which should then automatically transform
the coordinates.
Markus M
Thanks all!
Jose
grass-user mailing list
grass-user@lists.osgeo.org
2013/2/26 Markus Metz <markus.metz.giswork@gmail.com>:
AFAIK, PostGIS cannot print neither calculate transformation matrices.
User must obtain matrices values from somewhere. [sorry if this thread
became off-topic]
the coordinates.
I will try it. Thank you for update me!
Salud!
Jose
