[GRASS-user] v.variogram: maxdist and nlag
Dear Grass users
I am using grass 6.2.3 and have downloaded the v.variogram module from the Grass_AddOns website (http://grass.osgeo.org/wiki/GRASS_AddOns#Vector_add-ons). I wish to run the v.variogram module on a number of forest compartments for which I have LiDAR canopy heights. I have tried various combinations of maxdist and nlags but cant seem to find the 'sweet-spot' so to say.
A colleague of mine suggested that the lag distance multiplied by the number of lags should equal about half the largest distance within a particular compartment. Is this a suitable 'rule-of-thumb' to use?
I am interested in identifying the range of the semi-variogram as this value will determine the width of pseudo-flight lines I intend to use to sample the lidar data. Our point density is upwards of 5 points per square meter captured over even-aged managed Eucalyptus plantations with an espacement of 2 meters between trees and 3 meters between rows. Given the structural characteristics one would assume that semi-variance should reach a plateau (sill) at around 6m (canopy width), however my preliminary research indicates that the location of the plateau varies based on maxdist and nlags, how does one manage this to effectively quantify the distance at which spatial auto-correlation no longer applies?
I hope this all makes sense and that the question is appropriate for this mailing list.
Many thanks and looking forward to your responses.
Wesley
Wesley Roberts MSc.
Researcher
Earth Observation Research Group (Ecosystems)
Natural Resources and the Environment
CSIR
Tel: +27 (21) 888-2490
Fax: +27 (21) 888-2693
"To know the road ahead, ask those coming back."
- Chinese proverb
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean. MailScanner thanks Transtec Computers for their support.
On Fri, Aug 15, 2008 at 2:11 AM, Wesley Roberts <wroberts@csir.co.za> wrote:
Dear Grass users
Since v.variogram is actually using some functionality in R, it might
be best to work with the data directly in R-- preferably with the
gstat package. This might give some more flexibility in tuning
variogram calculations. In addition, you should be able to estimate
anisotropy, which will confound variogram-based inference.
I would suggest posting these type of questions to the r-sig-geo
mailing list. there are several accomplished geostat gurus there who
could probably answer this question.
I would argue that this is a fractal problem with no definite, finite
solution. Try generating a varigram map:
http://casoilresource.lawr.ucdavis.edu/drupal/node/442
* warning I am having some problems with the syntax highlighter, so
there are some spurious '\' characters in the code listings on that
page.
Dylan
Wesley
Wesley Roberts MSc.
Researcher
CSIR
- Chinese proverb
grass-user mailing list
grass-user@lists.osgeo.org
Dear Grass users
page.
Dylan
Wesley
Wesley Roberts MSc.
Researcher
CSIR
- Chinese proverb
