[GRASS-user] v. vol. rst tension parameters
Hi
with a 3d data set and with variable density of dat points, if i want to interpolate a property far away where there are no data points, how does the tension parameters affect the Search Radius? is there a way to define similar to a semi variogram for the search distance?
also my data set is strongly correlate vertically with some abrupt changes (soil borehole information) and data points are very dense along bh, but very soarse between bh locations. is there a way to apply different tension parameters vertically from horizontally?
