[GRASS-user] v.voronoi SegFault
Hi List
Running v.voronoi in Grass 6.4 (.deb package) and 6.5 svn on Debian I get segmentation fault error:
GRASS 6.5.svn (Basilicata):~ > v.voronoi input=stazioni@suolo_paes output=voronoi --overwrite
WARNING: Vector map already exists and will be overwritten
Reading sites…
Voronoi triangulation…
Segmentation fault
It does create a map, which is:
GRASS 6.5.svn (Basilicata):~ > v.info map=voronoi
WARNING: Coor files of vector map <voronoi@suolo_paes> is larger than it
should be (14 bytes excess)
| Layer: voronoi |
| Mapset: suolo_paes |
| Database: /home/madi/grassdata |
| Title: |
| Map scale: 1:1 |
| Map format: native |
| Name of creator: madi |
| Organization: |
Source date: Tue Dec 7 14:22:51 2010
Type of Map: vector (level: 1)
Number of points: 0 Number of areas: 0
Number of lines: 0 Number of islands: 0
Number of boundaries: 0 Number of faces: 0
Number of centroids: 0 Number of kernels: 0
Map is 3D: No
Number of dblinks: 0
Projection: Universal Transverse Mercator (zone 0)
N: 0 S: 0
E: 0 W: 0
Digitization threshold: 0
Comments:
Any suggest?
Thank you in advance
-Margherita
