Friends,
I have an vector area map with numerous polygons with centroids. When I do
v.what.rast vector=A raster=B column=C
It appears to run, but doesn't actually enter any data into column C in the associated table in Postgres. Reading the help file, I suspect this is because A is an area instead of a point map, but the areas do have centroids which I would expect v.what.rast to employ.
I could import the centroids as a separate points map, but then they're not associated with the table in Postgres.
What's considered best practices in associating polygon centroids with other rasters or vector areas?
Thanks, Dave
Hi Dave,
what I did in this case, was, as you said, to convert the centroids to points and then run v.what.rast.
One possibility to get the information to your table:
1- Convert the polygons (the categories) to raster with r.to.vect.
2- Do a v.what.rast with this "raster-area" map.
3- Make a table update and use 2- for identifying the right items.
I hope you like it,
Achim
Am 10.06.2010 19:40, schrieb Dave Roberts:
Friends,
Thanks, Dave
