Using Grass7 n wndows (osgeo4win).
I’m running v.what.vect and in the GUI, when I select the query column, the columns shows are the ones from the layer to be update and not from the query layer.
I can run the command correctily if I type the correct query column name. It’s just the dropdown list that is incorrect.
Daniel
