[GRASS-user] Variables in r.mapcalc other than raster?
Hello,
I have to perform some complex calculations on several hundreds of maps using a shell script. A set of variables would ease the task, therefore my question: Is there any possibility to use a set of predefined variables (no maps!) in r.mapcalc? - It seems to me as if it is always looking for maps and consequently states "i is not a map".
Is there any way to do this?
Roland
On 22/01/08 12:07, Roland Pape wrote:
Hello,
Have you checked http://grass.itc.it/gdp/raster/mapcalc-algebra.pdf ? There is a section on temporary variables, but I'm not sure if these aren't also "map" variables.
Moritz
Hello Moritz,
unfortunately, the temporary variables there also seem to be "map" variables...
Hello,
Moritz
Where does r.mapcalc get the expression from? If it's passed as a
command-line argument, the shell will perform variable substitution
within a double-quoted string. The shell will also perform
substitution within here documents.
If the expression is being read from a file, you'll need to arrange
for the substitutions to be performed using e.g. sed.
thanks to all for help!
As recommended in the manual, I put single quotes around my expressions and got "invalid map" for any "no-map" variables. Using double quotes instead solved the problem. - Sometimes it is rather simple...
Best regards,
Roland
