[GRASS-user] Vector dbf files + Spatial join
Hi Markus,
I tried to upgrade using the links from the announcement. I added the respective repositories to my sources.list file and upgraded no problem. I now have 6.2.3, unfortunately this does not include the v.db.join. I am now downloading the 6.3 source and am going to compile using that. Do I need to uninstall 6.2.3 before I compile?
Also I found the v.db.join script at
http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/scripts
Can I use this script in 6.2.3? If so how do I go about compiling and using?
Many thanks,
Wesley
Wesley Roberts MSc.
Researcher: Forest Assessment (Remote Sensing & GIS)
Forestry and Forest Products Research Centre
CSIR
Tel: +27 (31) 242-2353
Fax: +27 (31) 261-1216
http://ffp.csir.co.za/
"To know the road ahead, ask those coming back."
- Chinese proverb
"Markus Neteler" <neteler@osgeo.org> 06/24/08 12:26 PM >>>
On Tue, Jun 24, 2008 at 12:19 PM, Wesley Roberts <wroberts@csir.co.za> wrote:
Hi Markus,
Thanks for the help but unfortunately I don't seem to have the v.db.join application. When I execute v.db.join within grass I get an error
bash: v.db.join: command not found
I am using Grass version 6.2.2 do I need to upgrade to 6.3 or is the v.db.join a sqlite command?
Yes, it was introduced in 6.3.0:
http://grass.osgeo.org/announces/announce_grass630.html
You will like all the other improvements, too :slight_smile:
Best
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean. MailScanner thanks Transtec Computers for their support.
Hi Wesley,
On Tue, Jun 24, 2008 at 1:50 PM, Wesley Roberts <wroberts@csir.co.za> wrote:
Hi Markus,
As mentioned, we introduced it in 6.3.0.
No, you can keep both in parallel.
I am not sure of v.db.join makes use of 6.3.0 functionality. It's just a script
(so copying is enough in theory). Say, it's rather unlikely that it
works with 6.2.x.
You can try of course.
