[GRASS-user] Vector digitizer not available
Dear all,
this is what i get on the windows console when I start grass.
I am unable to digitize the raster layers.
C:>“D:\OSGEO4W\apps\grass\grass-6.4.0svn”\etc\init.bat -wxpython
WARNING: Vector digitizer is not available (No module named _grass6_wxvdigit).
Any suggestions!
Tks!
Ambrish
Match ‘n’ Make new friends with the cool match-meter. Join the Planet with you Hotmail ID. Drag n’ drop
2009/9/10 ambrish dhaka <ambijat@hotmail.com>:
C:\>"D:\OSGEO4W\apps\grass\grass-6.4.0svn"\etc\init.bat -wxpython
_grass6_wxvdigit).
simply wxGUI extensions (vector digitizer & 3D view mode) are not
working under MS Windows, see [1].
Martin
[1] http://trac.osgeo.org/grass/ticket/541
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Hello,
a few days ago, I wrote a message to the german GRASS List. I have trouble by startung QGIS using Linux 9.04. I've installed QGIS first some month ago, and the programm worked without any problems. But now, when I start there is the Startup Windows but then it shut down. The Terminal gives the error message: Segemtation fault.
Because of this error I updated the former Version 1.0.xx to the unstable 1.3.0 from this Launchpad sources:
deb http://ppa.launchpad.net/qgis/unstable/ubuntu jaunty main deb-src http://ppa.launchpad.net/qgis/unstable/ubuntu jaunty main
But the error message is still the same as before. So I think it's not really a problem of the installed version. Do somebody know this and can give some advice to solve it?
Benedikt
main
if you update from the UbuntuGIS repository make sure you update GDAL
and GRASS from there as well.
what does this say:
$ dpkg -l grass qgis 'libgdal*'
Hamish
Dear Hamish and Benedikt
I appologize to join to this discuss, but I have the same problem as Benedikt.
Since I have been changed to linux mint(ubuntu 9.04) from SUSE 11.1 I can not start qgis. (either 1.2 nor 1.3)
the Qgis is stopping with the same segmentation error immediatelly after the Python modules are loading into
the dpkg list which you have asking for in my system is the following:
(nincs leírás)= no description
best regards
András
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Cfg-files/Unpacked/Failed-cfg/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Hold/Reinst-required/X=both-problems (Status,Err: uppercase=bad)
||/ Név Verzió Leírás
ii grass 6.4.0~rc5-3~ja Geographic Resources Analysis Support System
un libgdal-dev <nincs> (nincs leírás)
un libgdal-doc <nincs> (nincs leírás)
un libgdal1 <nincs> (nincs leírás)
un libgdal1-1.3.1 <nincs> (nincs leírás)
un libgdal1-1.3.2 <nincs> (nincs leírás)
un libgdal1-1.4.0 <nincs> (nincs leírás)
ii libgdal1-1.5.0 1.5.4-4 Geospatial Data Abstraction Library
pn libgdal1-1.5.0 <nincs> (nincs leírás)
ii libgdal1-1.6.0 1.6.2-3~jaunty Geospatial Data Abstraction Library
ii libgdal1-1.6.0 1.6.2-3~jaunty GRASS extension for the GDAL library
ii libgdal1-dev 1.6.2-3~jaunty Geospatial Data Abstraction Library - Develo
un libgdal1c2 <nincs> (nincs leírás)
un libgdal1c2a <nincs> (nincs leírás)
ii qgis 1.3.0-1~jaunty Geographic Information System (GIS)
main
what does this say:
Hamish
grass-user mailing list
grass-user@lists.osgeo.org
Bödőcs András, PhD
ELTE Régészettudományi Intézet
Térinformatika Labor
Budapest, H-1088
Múzeum krt. 4/b.
T: +36-1-4116554, +36-1-4855200/2910
F: +36-1-4116553
E-mail: bodocs@ludens.elte.hu
www: http://www.regeszettudomany.hu
some reports in,
Jorge wrote:
I've started qgis without any problem and loaded some plugins.
See screenshot at with north arrow plugin and so on
http://img44.yfrog.com/i/screenshotkj.png/
[on the UbuntuGIS mailing list, where this conversation should be
continued, (as they made the package) http://lists.osgeo.org , ...]
Alan wrote:
I would tell him to install the lastest qgis package, which is probably
build against the right dependencies: qgis - 1.3.0-1~jaunty3
Benedikt. Since I have been changed to linux mint(ubuntu 9.04) from SUSE
Develo un libgdal1c2 <nincs> (nincs leírás)
akkk, terminal just 1 character too narrow to show the full versions ...
Benedikt wrote:
Thanks for your help. But I not really know what have to do next.
Do I have to type this term in the Terminal??
yes, to see what versions of the packages you have installed.
pull the terminal wide enough so that the full version number shows.
to follow Alan's advice, try upgrading and see if there are any
new packages waiting in the UbuntuGIS repository.
Hamish
OK, that’s the results:
benedikt@inspiron1525:~$ dpkg -l grass qgis ‘libgdal*’
Gewünscht=Unbekannt/Installieren/R=Entfernen/P=Vollständig Löschen/Halten
Status=Nicht/Installiert/Config/U=Entpackt/Fehlgeschl. Konfiguration/
Halb installiert/Trigger erWartet/Trigger anhängig
Benedikt wrote:
benedikt@inspiron1525:~$ dpkg -l grass qgis 'libgdal*'
ii grass 6.2.3-2.1
ii libgdal1-1.5.0 1.5.2-3ubuntu1
ii libgdal1-1.5.0-grass 1.5.2-1
GRASS extension for the Geospatial Data Abstraction Library
ii libgdal1-1.6.0 1.6.0-1
ii qgis 1.3.0-1~jaunty6
where does 1.3.0-1~jaunty6 come from? AFAICT that doesn't
exist yet from UbuntuGIS. Are you using another source?
I've installed the newest QGIS packages allready. But I
don't think the error is connected with these version.
the latest from ubuntuGIS repo are:
libgdal1-1.6.0_1.6.2-3~jaunty1
grass_6.4.0~rc5-3~jaunty1
qgis_1.3.0-1~jaunty3
all three need to be updated & in sync. You can't use a latest
QGIS with an older GDAL library. The ABI will have changed and
the result will be a segfault.
as this is not a GRASS matter it should continue on the
UbuntuGIS mailing list: http://lists.osgeo.org
regards,
Hamish
