I have a 90 files that are supposed to be figures but have the Microsoft
Access .mdb extension and another 88 files with ARC/GIS .mxd extensions.
When I look at supported formats for v.in.ogr I don't see either of those
after sorting the list (why isn't it sorted anyway?).
Is there a way to import the vectors and associated (I presume) data into
GRASS7x?
Hey Rich, the .mxd files are project files for ESRI's ArcGIS and don't really contain any "data". They can be opened with ArcMap for example and are used to mostly conduct geospatial analysis and map production.
The other files you have, .mdb may contain the spatial data but I think that data cannot be converted or extracted from within grass unless GDAL has been built with .mdb support [1][2].
GRASS7x?
The MXD files are just ArcGIS Map documents. They will hold no data - only symbology.
You'll need to get your data out of the personal geodatabase files (the .mdb files). It's been a while since I've tackled that - I wrote a tutorial for doing this in QGIS. People have had hit or miss luck with the tutorial - http://www.northrivergeographic.com/qgis-accessing-personal-geodatabase. It works for me (win 10 64 bit with QGIS).
Personal geodatabases were a first attempt at a database format for ESRI when they left coverages. It's mostly been abandoned for the File Based Geodatabase.
I know that probably isn't helping much - but - it might get you started. I don't think there's a straight forward way to push that into GRASS - there will need to be a few steps before hand.
Randy
GRASS7x?
Randal Hale
North River Geographic Systems, Inc http://www.northrivergeographic.com
423.653.3611 rjhale@northrivergeographic.com
twitter:rjhale
Donovan,
Interesting. That's the problem with proprietary data: not everyone can
access it. And this is a shame for documents produced by federal agencies
since we all pay their costs.
I doubt they have spatial data. I think I have a tool here that converts
.mdb to something usable.
Randy,
Therefore, useless to me.
I think I still have an .mdb converter here somewhere. I'll go look for
it. I work with only linux and F/OSS tools. And I can still access data from
20+ years ago.
Okay. If I decide to pursue this I'll do more digging.
only
symbology.
Randy,
the
from
20+ years ago.
Rich
grass-user mailing list
I would look at the excellent MDB-tools package (http://mdbtools.sourceforge.net). mdb-export will pull a specific layer out of the mdb file. Unless it's a point coverage it's not going to contain spatial data though, and even for point coverages it's rare to the the point coordinates in the table.
The access2csv java.jar program also claims to do .mdb, but I have only used it for .accdb files because mdb-export works so well.
As I recall, you're a linux guy, so you should have little trouble with this.
For the spatial data you'll have to find a shape file or coverage.
Dave
On 10/27/16 10:46, Rich Shepard wrote:
only symbology.
Randy,
the
from
20+ years ago.
See http://www.gdal.org/drv_pgeo.html
try accordingly to this GDAL driver manual ogrinfo to your mdb files.
it works for me on windows and linux to read personal geodatabases with the
. Mdb extension.
Dave,
Yes, I have/had this; don't know if it's still on the hard drive ... yes,
it is. There's a SlackBuilds.org package for this and it's still installed.
There is another sub-directory with shapefiles.
This is all for an idea that I might pursue if there's time for it.
I'm working on a page for my tutorial on "GRASS for Ecologists" called "Living with ESRI". Let me know how your project works out so I can benefit from your experience.
Dave
On 10/27/16 11:13, Rich Shepard wrote:
Dave,
On Thu, Oct 27, 2016 at 2:51 PM, Dave Roberts <droberts@montana.edu> wrote:
Rich,
Dave
Awesome, please share it here once you are finished, or even before.
Thank you,
Anna
Dave,
yes,
installed.
