[GRASS-user] vector layer labelling doesn't work....
it's the first time I try to use labelling on a polygonal vector layer
in grass 6.4.svn, and I can't make it work.
d.vect map=sst_sardegna@CRA-TASK2 -c color=0:0:0 lcolor=0:0:0
fcolor=170:170:170 display=shape,attr type=point,line,boundary,area
icon=basic/circle size=5 layer=1 {att=UC_SIGLA} lsize=10 xref=left
yref=center llayer=1
This is the command on the output display. It sets {att=UC_SIGLA} (why
does it use parenthesis?) but no labels are displayed...
Giovanni
On 08/08/08 11:06, G. Allegri wrote:
You need to add centroid to the list of types. The label is attached to the centroid and if you do not display that, the label won't display either. If you're annoyed by the centroid circle, set its size to 1 which makes it hardly visible.
Moritz
2008/8/8 Moritz Lennert <mlennert@club.worldonline.be>:
hardly visible.
I usually set to basic/point, size 1. Hardly noticeable at all.
Paulo Marcondes = PU1/PU2PIX
-22.915 -42.224 = GG86jc
Thanks Moritz, sorry for the stupid question...staying all the day in
front of the screen I coudn't see I was missing centroids :slight_smile:
hardly visible.
Moritz
2008/8/8 G. Allegri <giohappy@gmail.com>:
You're not alone =]
that ocurred to me once.
Maybe, we should ask devels to change default d.vect behaviour, so
when labeling is selected, centroids should be automagically selected
too?
2008/8/8 Paulo Marcondes <paulomarcondes@gmail.com>:
too?
it would be too much "user-friendly" from my point of view, then maybe
d.vect would be not my friend anymore;-)) I would leave decision on
the user, which feature types will be displayed...
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Anyway I will change in my build :slight_smile:
gui/tcltk/gis.m/vector.tcl - Line 143:
set opt($count,1,type_centroid) 0 -> set opt($count,1,type_centroid) 1
2008/8/8 Martin Landa <landa.martin@gmail.com>:
too?
Martin
On Fri, 2008-08-08 at 17:07 +0200, Martin Landa wrote:
> too?
Martin
What about a warning message "centroid displaying enabled?" when using
"llayer" option?
Cheers, Nikos
in wxGUI it takes default d.vect type options, so
"point,line,boundary,centroid,area,face". Not sure why TCL/TK differs
here.
Martin
too?
You might be right.
I thought of this, because it seems to be a common GRASS-newbie mistake.
But also, that is a mistake one only commits once. (or just a few times)
On 08/08/08 17:13, Martin Landa wrote:
That means always displaying centroids, not only when labelling is set.
here.
It was decided quite a while ago that having those circles by default was a bit annoying (even worse with the crosses) and that in most cases, when one wants to display areas, one does not need the centroids.
>> too?
Could you elaborate on this ? I think that it seems logical to do what the user asks for. When labelling is asked for, this means the user wants the labels to appear, so automagically setting centroid display in that case doesn't seem too much interference to me...
Moritz
Yes. I set it this way because I prefer having centroids by default...
If I'm not wrong centroids were set on by default. I didn't make this
"mistake" before, but I've used labeling lot of times.
I mean, in some previous versions...
see http://lists.osgeo.org/pipermail/grass-dev/2007-February/028873.html and following, notably
http://lists.osgeo.org/pipermail/grass-dev/2007-February/028908.html
So, it's been off since 1 1/2 year, at least in trunk...
But, to come back to the labelling issues, AFAICT, all it would take is this:
Index: display/d.vect/main.c
--- display/d.vect/main.c (révision 32646)
+++ display/d.vect/main.c (copie de travail)
@@ -565,6 +565,7 @@
             break;
         case 'a':
             display |= DISP_ATTR;
+ type |= GV_CENTROID;
             break;
         case 'z':
             display |= DISP_ZCOOR;
Martin, are you really against this ? Anyone else ? Otherwise, I would commit.
Moritz
this:
@@ -565,6 +565,7 @@
           break;
       case 'a':
           break;
       case 'z':
commit.
I would hesitate to add GV_CENTROID automatically when displaying
labels. Attributes are connected to the primitives like points,
centroids, lines or boundaries, not areas! In d.vect when you ask to
display 'area', you ask for filling areas, nothing else. Labels are
not connected to areas but to the centroids. So you basically cannot
ask to display area labels. This should be explained in d.vect manual
rather then changing the code. Just my opinion.
Martin
Yes, ok Martin. But that would be for "user-friendness". Conceptually,
with your logic, also d.what.vect should work only if a centroid is
clicked, not on the whole area...
Centroids are borned to make areas exist, so they're conceptually
strongly related, so it doesn't appear an error to me to consider
labels (attributes) directly related to areas... my two cents. I
repeat, just for "user-friendness"
