gui/tcltk/gis.m/vector.tcl - Line 143:
set opt($count,1,type_centroid) 0 -> set opt($count,1,type_centroid) 1
in wxGUI it takes default d.vect type options, so
"point,line,boundary,centroid,area,face". Not sure why TCL/TK differs
here.
The wxPython GUI uses the default, autogenerated GUI as a properties dialog. There are definite maintenance advantages to doing this, which is why we've done it. But it means that it comes up with whatever are the defaults for the module command.
The TclTk GUI has a custom coded properties window for each d.* command, meaning it does not have to use the command line defaults. In TclTk, I turned displaying the centroids off by default because they are really annoying and ugly in areas unless you have specific need to see them (just like direction is turned off in lines an boundaries).
If it is needed, I can add code to turn on centroids when area labeling is turned on in TclTk. But a better solution IMHO is to fix d.vect so that it is not *necessary* to have centroids showing in order to display labels for areas.
areas.
areas.
IMHO this is the best solution.
+1
Paulo Marcondes = PU1/PU2PIX
-22.915 -42.224 = GG86jc
the module command.
BTW, I have added this option to GUI preferences, user can overwrite
d.vect default type options from 'Config->Preferences-Command->Vector
settings'.
the module command.
settings'.
