[GRASS-user] vector layers
A watershed polygon has 10 boundaries, 1 area, 1 centroid, and 1 island. The data table always connects to the boundaries, showing associated attributes of the 10 individual lines. How can a similar table/layer be created that houses the data of the centroid and area?
Damon Grabow
NDSWC
First check with v.category option=report if the centroid has a
category in any layer.
If yes, and an attribute table for that layer does not exist
(v.db.connect -p), create a table for that layer with v.db.addtable.
If the centroid does not have a category in a separate layer, create one with
v.category option=add type=centroid layer=X
with X being a layer number not present in the output of v.category
option=report
Now create a table for layer X with v.db.addtable and you can upload
area/centroid attributes.
HTH,
Markus M
Damon Grabow
NDSWC
grass-user mailing list
grass-user@lists.osgeo.org
