[GRASS-user] Vector not getting imported in GRASS v7.0 latest svn.
After completion of the import process, following error message is displayed :
Command ‘d.vect map=%@%’ failed
Details: The bounding box of the map is outside the current
region, nothing drawn
% is to indicate that I tried several maps.
Points only layers are getting imported but polygon layer have problems.
I have checked the region, and it is correctly set.
Any idea.
Command 'd.vect map=%@%' failed
Have you tried to zoom to the selected map and/or zoom to the current
computational region?
Can you provide the output of v.info and g.region? Ideally, can you
also provide a (link to a) sample polygon vector for import?
Markus M
