[GRASS-user] Vector points behaving strangely after using v.what.vect
Hello all,
I created a vector points map in Grass with information on ecosystem characteristics based on various sources. This was to be used as input to create a training-set of a vector segment map with statistics for classification.
I tried to copy the cat- values of the segments to the points- map based on location as intermediate step by using v.what.vect. But this was not successful - Not all cat- values of the points vector map was updated, about 70% was. I tried then to update another (empty) column with the segment cat-values which also worked partially - it worked for most of the remaining which is about 25% of the total records and for non of the 70%. Now I notice that the records of the updated cat-values are behaving strangely. I can see the points in the map display, but if I highlight them in the table they are not highlighted in the map display. When I click to zoom to highlighted feature, I end-up somewhere else where it shouldn’t be. Also when I try to extract, copy or export the data, there seems to be disconnect between the attribute values and the location of the points. This happens with the ones of which the cat-values was updated, about 70% of the records. When simply displayed, without other operations, it looks fine and complete.
Is there a way to repair this disconnect?
Best,
Jamille
