[GRASS-user] vectors: how to find the gravitation centre of point data ?
Hi list,
is there an easy way to derive the centre of a cloud of points ?
I am aware that the set of vector points ("cloud of points") could be used to stake out a polygon/boundary and use v.centroid etc etc to derive in turn its' centroid, but I am hoping for an easier solution .. ?
This issue stems from working with v.to.db: currently it is not possible to upload xy coordinates for "multiploygons" into a database, i.e: Within a vector layer, there might be several boundaries which all share the same category value. If the "gravitational centre/ super-centroid" for these boundaries could be (conveniently) calculated, the v.to.db issue could be taken care of.
Peter
Dr. Peter Löwe
<peter.loewe@gmx.de>
Sensationsangebot verlängert: GMX FreeDSL - Telefonanschluss + DSL
für nur 16,37 Euro/mtl.!* http://dsl.gmx.de/?ac=OM.AD.PD003K1308T4569a
On 04/12/08 11:02, peter.loewe@gmx.de wrote:
Hi list,
Why not use v.dissolve on these polygons and then get the centroids of the result ?
Another (very wild) guess: what about the mean of the coordinates of the individual polygons' centroids ?
Moritz
the result ?
This option fails if the polygons don't have common borders. An example for this would be multiple polygons describing spatial exclaves of a territory/county/soil type, etc.
That would be great if it could be automated.
Peter
Moritz
Dr. Peter Löwe
Using a "real" DB-backend, it should be as easy as (assuming that when you say boundaries, you mean areas, each of which has a centroid):
- v.to.db type=centroid option=coor
- SELECT cat, avg(X), avg(Y) from TABLE group by cat
If you have boundaries with categories, but no centroids, I imagine that v.centroids + v.distance with upload=cat should do the trick to transfer boundary cats to their centroids.
Moritz
-------- Original-Nachricht --------
Datum: Fri, 05 Dec 2008 13:40:08 +0100
Von: Moritz Lennert <mlennert@club.worldonline.be>
An: "Peter Löwe" <peter.loewe@gmx.de>
CC: grass-user@lists.osgeo.org
Betreff: Re: [GRASS-user] vectors: how to find the gravitation centre of point data ?
>> the result ?
the
Very good point.
If this is combined with a previous step to create individual CATs for the exclave areas while preserving the original CAT in another column, we can successfully apply v.to.db even while several areas share the same ID (having the centroids xy-coordinates for all exclave-area) _plus_ having the coordinates for the super-centroid of all exclaves.
Northern winter might be the perfect time to write GRASS scripts for this kind of stuff..
Peter
Moritz
Dr. Peter Löwe
#spearfish
g.copy vect=archsites,tmp_arch
v.db.addcol tmp_arch column='x double, y double'
v.to.db tmp_arch option=coor columns=x,y
eval `v.univar -g tmp_arch column=x type=point | grep -w mean`
X_MEAN=$mean
eval `v.univar -g tmp_arch column=y type=point | grep -w mean`
Y_MEAN=$mean
echo "Center of point cloud: $X_MEAN, $Y_MEAN"
one thing there- v.univar output for y coord results in 4.92146e+06.
see trac bug #335 (improve variable output precision)
http://trac.osgeo.org/grass/ticket/335
Hamish
exclaves.
beware the "C" shape area where the center of gravity is outside of the area; centroids should always do a point-in-polygon test.
Hamish
