[GRASS-user] Virtual Mosaic import with r.external
Hello,
I was following along the Large raster data processing wiki with great interest:
http://grasswiki.osgeo.org/wiki/Large_raster_data_processing
My question is, when tiles are merged in GRASS using a virtual mosaic created with gdalbuildvrt, will transparent map collars be preserved? I see the man page for r.external talks about the requirement to build a mask or use r.mapcalc, but I don’t understand how I would apply that to a virtual mosaic. Is it possible?
Would a certain file format handle transparent border collars better than others?
Note that I already have all my tiles as GRASS rasters in my current location, alas I tried using r.patch running in parallel for the job first but it pretty much choked on the task. My attempt was terminated due to a power outage after running several weeks trying to create around 0.5 terrapixel mosaic.
Any suggestions how to best build a mosaic would be super appreciated!
Jeshua Lacock
Founder/Engineer
3DTOPO Incorporated
<http://3DTOPO.com>
Phone: 208.462.4171
It appears that GDAL_TIFF_INTERNAL_MASK may be just what I need to use. I wonder if that option is respected using r.external? Thanks!
I suppose that would apply to r.external.out as it seems to be related
to the creation of GeoTIFF (see http://www.gdal.org/frmt_gtiff.html).
Hi Markus,
Excellent, thank you for the tip!
Note I tried again using r.patch.many with a smaller batch last night (333 billion pixel mosiac) and it ran *much* better, but I think it is stuck now.
Here is a screen shot when it was cranking away:
<http://3DTOPO.com/r.patch.many.1.png&gt;
The “Bytes Read” has been going up continuously for the r.patch processes, but the bytes written hasn’t changed in over 8 hours and appears stuck at 57%. I think I can use r.patch.many for the job but I will have to break it into smaller sub-mosiacs first.
<http://3DTOPO.com/r.patch.many.2.png&gt;
If I understand importing a virtual mosaic correctly, I suspect using r.external with a virtual mosaic is the best way to accomplish the task at hand, but I welcome any advice!
Thanks again,
Jeshua Lacock
Founder/Engineer
3DTOPO Incorporated
<http://3DTOPO.com>
Phone: 208.462.4171
