Hello List!
I tried to import this image to GRASS GIS:
http://rapidfire.sci.gsfc.nasa.gov/gallery/?2003239-0827/Svalbard.A2003239.1300.250m.jpg
If you follow the "more info" link you'll see that the projection is soemthing like a Lambert Azimuthal (equal area?) aver a sphere, not an ellipsoid. Additionally, it's rotated.
I didn't manage to set up a location to import the file into with these parameters. Does anyone have an advice on this?
r.in.gdal can't import the file directly, as it's rotated.
I tried gdalwarp to rotate the file by the information in its .jgw file. r.in.gdal will then import the file but the problem of location steup stays.
I want the image to end up in an UTM33-location, so the import location has to be set up correctly for r.proj to perform nicely.
thanks in advance,
\flo.
Florian Kindl <florian.kindl@uibk.ac.at> writes:
> an ellipsoid.
There's a hack mentioned at [1], which sometimes helps to get
MODIS L3 data to work with GDAL.
> r.in.gdal can't import the file directly, as it's rotated. I tried
Currently, you'll probably need to use `gdalwarp' (as suggested
in [1]) to reproject the image, since GRASS (or PROJ.4) seems to
lack the support for the ``WGS84 datum + spherical projection''
combination.
I guess, PROJ 4.6.0 will support combining any datum with any
projection. It may cause GRASS to support the exact projections
used by MODIS L3 data.
[1] http://trac.osgeo.org/gdal/ticket/1239
