[GRASS-user] "WARNING: Line ignored as requested" in processing ASTER GDEM2 tiles
Hi list!
In processing ASTER GDEM2 tiles over Portugal, using r.denoise, I get (too)
many WARNINGS like:
WARNING: Not enough data columns. Incorrect delimiter or column number?
        Found the following character(s) in row 4296516:
        [-8.855 37.6686111111111]
and so on.
For example, using a for loop to execute the following
r.denoise --o in="${ASTGTM2}" out="${ASTGTM2}"_smoothed iterations=10
threshold=0.8 epsg=3763
failed for some tiles. What do the WARNING messages mean? Could it be that
the tiles are corrupted?
Also, no matter what color rules I try to apply to all (original) tiles, be it
with "-e" or without, the overall drawn tiles look weird, i.e. there is no
seamless integration of the tiles. This is something not expected normally.
Anyone experienced the same problem(s)?
Thank you, Nikos
On Fri, Jan 25, 2013 at 3:39 PM, Nikos Alexandris
<nik@nikosalexandris.net> wrote:
Hi list!
many WARNINGS like:
and so on.
Please try
http://grasswiki.osgeo.org/wiki/GRASS_Debugging#Shell_script_debugging
to figure out where it happens. A candidate is as usual "mdenoise"...
> (too) many WARNINGS like:
> 4296516:
> and so on.
Markus Neteler wrote:
Please try
Not sure whether it was "mdenoise" or "available system RAM". Looping over
the same process on a smaller set of maps, did complete successfully :-).
Nikos
